BIKELAND > FORUMS > ZX-14.com > Thread: License plate relocation NEW TOPIC NEW POLL POST REPLY
AZ ZX14
posted July 06, 2008 07:32 AM
I recently relocated my license plate and eliminated my rear fender and plate mount.
My license plate is currently mounted inside the undertail which is illuminated with an led.
My question is, will this create any issues with the law enforcement? The plate is visible from the rear and meets the illumination requirements.
Any input would be welcome.
2008 ZX-14
Flies out
PCIII / USB
Brocks Alien head
Puig DB Screen
posted July 06, 2008 07:46 AM
just depends on the law enforcement in your area. it looks visible to me.
Bawls
re-learning to ride
posted July 06, 2008 07:47 AM
got any pictures that aren't in a dimly lit room? I like the concept but would like to see some better pictures. Good work
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
AZ ZX14
posted July 06, 2008 08:07 AM
I will post some in better light. I was trying to show the visibility in the dark but the quality was poor.
2008 ZX-14
Flies out
PCIII / USB
Brocks Alien head
Puig DB Screen
AZ ZX14
posted July 06, 2008 08:32 AM
Revised photos
Here you go.
2008 ZX-14
Flies out
PCIII / USB
Brocks Alien head
Puig DB Screen
warbird
posted July 06, 2008 09:35 AM
Looks good to me................ How bout a couple of pics from the side showing the exhaust?
I'd Rather Be Roadracing.
warbird
posted July 06, 2008 09:37 AM
Another question.............when you install the centerstand...........does it eliminate the little rear fairing?
Tool man
posted July 06, 2008 09:51 AM
I think they might have a hard time reading the custom #s you have on the plate :P
Seriously....I'm in Az and have seen many mounted like that and nobody has told me any horror stories about any Az LEOs ticketing for such a placement
These are the Arizona state statutes
ARS 28-2354. License plates; attachment
(L96, Ch. 76, sec. 7)
A. A person shall display the license plate or plates as follows:
1. For a motor vehicle, motorcycle, trailer or semitrailer, on the rear.
2. For a vehicle for which two license plates are issued, the vehicle owner shall display either of the following:
(a) One plate on the rear.
(b) One plate on the front and one plate on the rear.
B. A person shall display all license plates as required by subsection A until their lawful use expires or is canceled or revoked. A person shall maintain each license plate so it is clearly legible. A person shall securely fasten each license plate to the vehicle as follows:
1. To prevent the plate from swinging.
2. At a height of at least twelve inches from the ground to the bottom of the plate.
3. In a position to be clearly visible.
(L06, Ch. 377, sec. 1. Eff. 1/1/09)
B. A person shall display all license plates as required by subsection A until their lawful use expires or is canceled or revoked. A person shall maintain each license plate so it is clearly legible and so that the name of this state at the top of the license plate is not obscured. A person shall securely fasten each license plate to the vehicle as follows:
I think you're fine
The banks are failing..
The banks are failing...
Invest in Ammo
AZ ZX14
posted July 06, 2008 09:54 AM
2008 ZX-14
Flies out
PCIII / USB
Brocks Alien head
Puig DB Screen
AZ ZX14
posted July 06, 2008 09:58 AM
The lower cowl cannot be used with the centerstand.
2008 ZX-14
Flies out
PCIII / USB
Brocks Alien head
Puig DB Screen
Bawls
re-learning to ride
posted July 06, 2008 10:21 AM
what is the knurled silver thing that is on the left side of the bike?
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
AZ ZX14
posted July 06, 2008 10:27 AM
It is the grab handle which is included with the centerstand kit. It gives you a place to hold while placing the bike onto the stand.
2008 ZX-14
Flies out
PCIII / USB
Brocks Alien head
Puig DB Screen
drewzx-14
Andrew
posted July 06, 2008 11:56 AM
i like the location of the plate. I just think out here you would probably get bothered for it. It looks very clean though. Also I believe out here you need a light shining on the plate. Hey but its all good. Just take it easy when you see your local law enforcement.
2009 Yamaha R1-SOLD!
2013 Zx-14R Green ABS
AZ ZX14
posted July 06, 2008 12:15 PM
Its hard to see but I have a low profile led mounted. The led is rectangular and visible in the first photo of this thread.
2008 ZX-14
Flies out
PCIII / USB
Brocks Alien head
Puig DB Screen
kawabonzai
Leader of the Back.
posted July 09, 2008 04:42 PM
What part of Az are you in? please say Tucson, I'm the only ZX-14 on the road it seams.
... Bonzai
2009 ZX-14 Candy Lime Green
AZ ZX14
posted July 09, 2008 06:15 PM
I'm in Phoenix but travel to Tucson every now and then. Usually around the Broadway/ Pantano area. The only other 14 owner Ive talked to from Tucson is currently surving in Iraq.
What color bike do you have? I've not seen another silver in the area yet?
2008 ZX-14
Flies out
PCIII / USB
Brocks Alien head
Puig DB Screen
MADDOGC5
posted July 10, 2008 05:42 AM
you have to remember that when you sit on the bike the rear tire moves through the suspension cycle and the plate then colud be covered... they would bust chops here in n.y. for that mount
LIFE IS ALL ABOUT ASS-you're either kissing it,covering it,working it off, trying to get a piece of it......or simply behaving like it!!!
Sticks_n_Stones
posted July 10, 2008 09:10 AM
They would write you up in Washington State for that, too, but only if the cop was being a dick. I love that grab handle, though! Where did you buy the center stand at? I bet they sell the handle seperately, and I also bet it could be installed on the r/h side, too. That way I could attach my bags to it instead of having to go all the way the the square rails - which means I have to use clear boxing tape on the fairings to keep from rubbing through the paint.
Nice chicken stripes, BTW. Those come in a KFC bucket? Cuzz they sure are big'uns! lol
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
Kawabonzai
Leader of the Back.
posted July 10, 2008 09:28 AM
I live near Tanque Verde / Sabino Canyon, only a few miles from Bdwy / Pantano.
I have the Black sparkly blue paint, a friend is supposedly going to buy an 08 silver over at Performance soon.
Email me if you go for a ride down here anytime ... KawaBonzai (at) Gmail (dot) Com
AZ ZX14
posted July 10, 2008 04:10 PM
Well so far no tickets. I'll keep you posted.
The center stand can be purchased of EBAY or other online sites. I recommend checking out www.cyclepartsnation.com. Their parts are typically 30% below retail and you should be able to order just the handle, mounts and hardware. I was considering getting the second handle as well.
2008 ZX-14
Flies out
PCIII / USB
Brocks Alien head
Puig DB Screen
hotzxrod
posted July 10, 2008 04:41 PM
its a fix a ticket at most . thats where mine always go. always have a cop friend sign it off.....
tilthewheelsfalloff
  Ignore this member    Click here to visit hotzxrod's homepage. Click here to send hotzxrod an AIM message.
Sticks_n_Stones
posted July 11, 2008 05:36 AM        Edited By: Sticks_n_Stones on 11 Jul 2008 06:37
here's mine, buddy of mine made it up. I'm really digging that handle though, just had to put the bike up on the rear stand again and am cant help but think how much easier it would be to do if there was a handle! Heck, I bet even the passender could probably use it... I'm gonna contact them about selling just the handle.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
AZ ZX14
posted July 12, 2008 12:28 PM
Sweet ride. Can you post some close up pics of your mount?
2008 ZX-14
Flies out
PCIII / USB
Brocks Alien head
Puig DB Screen
NYC ZX-14
Manager Star Toyota Bayside,NY
posted July 17, 2008 07:31 PM
I got pulled over and a warning to move my plate for having it mounted in EXACTLY the same spot. The highway cop said the plate must not be mounted forward of the rear wheel.
Currently?
2007 Kawasaki ZX-14, 1999 Kawasaki VN 750, 1976 Suzuki RE-5 Rotary
http://www.goldiesplating.com
  Ignore this member    Click here to visit NYC ZX-14's homepage.
dcjens
Wet side of Washington
posted July 17, 2008 08:53 PM
Washington cop said it must be viewed from 50ft and was skeptical of the undermount as this. He said it depends on the cop, donut or no donut day. Must be lit at night
Black 06
0.24784517288208 seconds processing time
