BIKELAND > FORUMS > ZX-14.com > Thread: Wanted: Info on Turbos for ZX-14 NEW TOPIC NEW POLL POST REPLY
Boss69
posted June 23, 2008 03:03 PM
I am looking into a turbo for my 14 and would like to get some input from owners who have already been there/have a Turbo on their bike.
Who makes yours?
Was it a kit or did you make it up?
How do you like it?
How much power can be made safely with stock motor?
Any engine mods?
How much Power are you currently making?
What is it capable of? with and without engine mods
..........My friends think I am outta my mind.
All I hear is "like you need MORE power for that thing"
Any and All info appreciated.
Thanks, Jack
'07 Blue ZX-14 Turbo (FOR SALE)
'07 Victory Jackpot Ness Edition (FOR SALE)
'04 EX500, for son and wife to learn on.(sold)
'78 Z1-R (sold)
'75 Z1 900 (sold)
davej
posted June 23, 2008 03:19 PM        Edited By: davej on 23 Jun 2008 16:32
I have 7800 miles on a Muzzy Stage 1 kit @ 5lbs making 235hp at 4225' elevation. No engine mods, minor blow by at WOT. 200 lb rider, run 10.20 @ 146 avg. Don't count tail wind runs. Stock wheel base with Muzzy lowering link at the middle. This is a street set-up not dedicated for the strip. There are bikes with slicks and wheelie bars running in the 8's with the same top-end that I have. It is not the same ZX-14 and don't have a moments regret, also use pump gas only. Stock 14 at this altitude with a 190 lb. rider run 10.30 at 133mph lowered all the way and strapped with PCIII. Turbo kit also has a PC III which is not an option but a must. MPG avg is 43.3 one note is that you have someone map it on a dyno that has experience, above 5lbs boost you need a larger fuel pump with regulator..
Triumph guy
Boss69
posted June 23, 2008 05:42 PM
Thanks for the great info!
There must be some other kits out there........
Jack
'78 Z1-R (sold)
'75 Z1 900 (sold)
Hurricane
posted June 23, 2008 07:54 PM
Try this guy at:
http://www.atp-hd.com/
He builds a very nice turbo for the ZX-14. I have seen it and rode it. WOW!!!
He knows his stuff! Call him, his name is Harry. American Turbo's.
(Boy does this sound like an advertisement or what!)
Boss69
posted June 24, 2008 12:47 AM
Try this guy at:
All ATP shows kits for are Harleys???? Not sure he is the guy I need to see........
'78 Z1-R (sold)
'75 Z1 900 (sold)
zxbob
posted June 24, 2008 03:17 AM
Call Harry at ATP.
I have the ATP kit on my bike ~ its been on there a year and a half with over
10K mile since done. No issues what so ever !
Bob
posted June 24, 2008 06:34 AM
the ATP kit is the only one thus far that does not require an oil scavenge pump for the turbo!
kimski2001
posted June 24, 2008 07:53 AM
Call Harry at ATP.
Bob
im venturing off to the turbo world and noticed you saying 10,000 miles and no probs.whats your secret? and what kind of pwer you making?
1st14injax
davej
posted June 24, 2008 09:32 AM        Edited By: davej on 24 Jun 2008 10:48
How far away is the turbo from the exhaust ports, where is it in relation to the center of gravity? I like the weight low and in front of the engine for cooling and wheelies, (or the lack thereof). Never have been above the third bar cooling but that was probably from the mapping and location of the turbo. Scavenge pump is heavy duty gear type with low amp draw. Would be less to worry about but how many parts does the bike have already?
Triumph guy
posted June 24, 2008 09:57 AM        Edited By: dubious on 24 Jun 2008 11:15
I am not questioning the weight, location or stating anything other than it does not require a scavenge pump, and I like the fact the oiling system is foolproof.
I would hate to blow out cartridge seals, or burn up a motor due to faulty scavenge pump, which has been known to happen with other bikes using one.
Yes depends on pump....
I was providing some usable info, to make an informed decision.
to each their own!
Also ATP uses a superior turbo IMO... GT30R dual ball brg, capable of making ~475 HP.
Muzzy stage 2 has a nice fuel rail and optional larger injectors...and a plate to remove the stock pump and filter/ regulator... plus more $$$$
They all have pluses and negatives... depends what you want to do with it, and what is important to you personally.
The cyclelogic kit is the most cost effective, but I am skeptical of it reliability....I can not make any certain claims...
I have not built ridden, or tested all of them.
Heck, I haven't ridden any... YET....I decided to build up my engine, and getting all the engine parts has become an ordeal.
I think Orient express has built tested and ran all 4.... you might want their opinion rather than ours...and I am sure they will comment on all of the pluses and negatives of each system.
I was told Hahn assisted Harry with developing the ATP zx14 kit.... if that comforts you any.
1badzx12r
posted June 24, 2008 10:21 AM
Call Harry at ATP.
Bob
secret is don't ride it hard... or it will pop just like the rest ...as long as i stayed out of big boost everything was great or just short boost....but f you stay on boost goodbye more than 1 way
davej
posted June 24, 2008 03:00 PM        Edited By: davej on 24 Jun 2008 16:20
Use my 14 for 99.7% street & highway. Tires last about 3 weeks lately and this is only 235 horse. Had the same concerns about using ball bearings instead of fluid bearings for long life in the turbo. If the pump fails you smoke, if a bearing fails you poke.I Build boost at 3500 rpms so you may build boost at 3000? Just me maybe, at the shop here we do alot of turbo work for diesels in the manufacturing and R&D end. Personally I would rather have something simple to fix. We use ceramic bearings in many of our high speed spindles and they are excellent but don't run any where near turbo rpms, they are also temp controlled and mist lubricated with Velocite 6 or 10. these main rotors on turbos spin 150,000 + rpms. You do seem to be having good luck with the ball bearings though, do you have an hour figure on their life?
Triumph guy
Hurricane
posted June 24, 2008 03:26 PM
Harry is your guy.
His web site shows Harley's because they buy more turbo's than anyone.
I have seen his work and I believe it to be one of the best I have seen!
He has a 06 making 310hp with a stock engine. He let me drive it because I was interested in a turbo. Unbelievable the power it makes. I was truely impressed!!!
Call and just talk to him about it.
0.22783517837524 seconds processing time
