specialzx14
posted May 13, 2008 03:38 PM
nitrous question
these kits im lookin at say they work with the air sensor. i was told we dont have one. if you use the power commander to tune with the nitrous does it run right when your not spraying it im confused please help before i order a kit
ninja12
posted May 13, 2008 04:59 PM
Put a 100% throttle switch on the spray , and map for spray at 80-100%
You will loose some HP from rich condition if you race with that map.
Regular riding will not change. If you want the best of both world you need a wet kit
or a way to add fuel at notrous activation.
billeason
posted May 13, 2008 06:21 PM
Install a p/c hub with hub switch, It will let you have two maps on board 1 for nos 1 on motor at the flip of the switch. Whatever you do dont spray without adding fuel,the sensors won't handle the hit consistent enough! If your using the dyno tune kit, use the daul nozzle kit in the ram air tubes'' they work great. Also stay at 40 shot max with a dry fogger system no matter who makes it or you will have motor troubles. Bill...
bill eason
specialzx14
posted May 13, 2008 06:36 PM
where and how much will one of these hub switches cost
ZXLNT
posted May 13, 2008 07:48 PM
From dynojet and about 165-170 dollars or so..
BlackMagic14
posted May 13, 2008 08:24 PM
Does a zx14 have an air temperature sensor???
ZXLNT
posted May 14, 2008 01:57 AM
Yes a couple in fact, an inlet air temperature sensor and probably an ambient air temp sensor. Your best bet is to use the power commander to give the engine the proper fueling..
