BIKELAND > FORUMS > ZX-14.com > Thread: Manual Cam Chain adjusters?? NEW TOPIC NEW POLL POST REPLY
Nelson Taylor
posted May 08, 2008 12:09 PM
I have noticed my now rattles upon start up and then gets quiet once it warms up. Bike runs fine after it warms up. Cam chain is what I believe it is.
Anyone had this problem? and Has anyone tried the APE adjuster?
9k miles on the clock and lots of 1/4mile sprints.
Best #'s
1.54
4.03
6.02 @ 121mph
(Stock Wheelbase) 2006 ZX14
zxbob
posted May 08, 2008 02:54 PM
The 14 is know for it "start up" timing chain adjuster rattle ..... its normal !
I have put the APE adjuster in my bike and the rattle is gone.
Bob
BlackMagic14
posted May 08, 2008 07:56 PM
Bob how big of a job was it putting the Cam chain tensioner on?
posted May 08, 2008 08:00 PM
easy as pie!
remove the old one and bolt the new one on!, adjust and ride away!
ZXGRIFF
posted May 08, 2008 08:09 PM
Which one did you use, manual or updated factory?
Nelson Taylor
posted May 08, 2008 08:17 PM
I see can how the installation would be simple.
Its easy to get to but I am wondering how does one know when they've acquired the right adjustment? What would be the sign that its too tight?
I am going to buy the APE one.
I'll let you all know if it shuts this thing up upon start up.
Best #'s
1.54
4.03
6.02 @ 121mph
ninja14
posted May 08, 2008 10:32 PM
Just be sure to adj it properly - there are "fragile" chain guides in there.
2006 Turbo ZX-14.
2005 V-max 20th Anniv.
87gtNOS
posted May 09, 2008 10:43 AM
I have the 08 Concours adjuster. Well it's still at the dealer...I will go get it on Monday.
I assume it's as simple as removing the old one, and putting in the new one?
01 ZX12R
kaw now
posted May 09, 2008 10:54 AM
You say rattles on start up then goes quiet when warmed up. I think most as mine does rattles for maybe 1second then is quiet. To me as so many other 14 items is acceptable. Why f*** with something so minor? I wouldn't want the manual adjuster unless there was a record of the original one failing because you will have to periodically adjust the Ape adjuster as chain wears.
blackbullet76
posted May 09, 2008 06:39 PM
I agree. I had an APE on my 01 zx6r and I was adjusting it a little about every two weeks. I rode it alot and I would notice when it would get louder than normal. I'm sticking with the hydraulic one on my 14.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
87gtNOS
posted May 13, 2008 09:33 AM
I now have it in my hand....I also ordered the (I forget what bike used what..) the Oring and the gasket. Either the Concours, or the ZX used the Oring, the other uses a gasket. Not sure which one to use, I'll decide when I change the old one.
So once again, as simple as removing the old one, and putting in the new one?
01 ZX12R
0.23660802841187 seconds processing time
