BIKELAND > FORUMS > ZX-14.com > Thread: what sprocket combo are 200mph guys use NEW TOPIC NEW POLL POST REPLY
acapone72
08 zx14 blk n red
posted April 13, 2008 09:53 PM
lookin for sprocket combos 2 go 200 with a 240 pound fully suited rider
acapone72
BobC
posted April 13, 2008 10:32 PM
If your bike is without Turbo or Nitrous then try a 40 tooth at the rear.
I use 17/40 to go 203mph in still conditions.
18/41 got me to 205mph but that was a bit overgeared for the power my engine was making, just lucky with a tail wind that day.
If you have a Turbo etc then it will pull a higher gear.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
dutchzx14
posted April 14, 2008 01:11 AM
I used 17/39, wih backwind 326km/h. 225hp on the crank.
  Ignore this member    Click here to visit dutchzx14's homepage.
BobC
posted April 14, 2008 04:32 AM        Edited By: BobC on 14 Apr 2008 06:05
That's quite interesting.
You have 225 at the crank and 17/39 gave you 326 km/h
I have 192.9 at the rear wheel and 17/40 gave me 326 km/h (203 mph)
Different conditions and track, getting the correct gearing is SO important.
For comparison, a friend of mine got a standard 1400 (17/41 gearing and stock exhaust) to 198.7 mph, with a big tail wind, it hit the engine rev limiter just as it reached the speed trap. (Speedo Healer fitted of course ).
This means the true engine rev limiter is at 10500 rpm, (ignore the optimistic rev counter which will be showing around 11300 rpm)
Using this figure:
max speed on 17/40 should be 203.6 mph or 327.7 km/h
max speed on 17/39 should be 208.8 mph or 336 km/h
Answering the original question, if you are 240lbs suited you may have a problem with aerodynamics. This is just as important as power and gearing for high speeds. If you can't tuck in behind the fairing you won't do it. Maybe a drag seat would help, as does lowering the bike and removing mirrors and so on. Good luck, let us know how you go.
Stock wheelbase
acapone72
08 zx14 blk n red
posted April 14, 2008 06:15 AM
tnks for input guys i have drag seat on way and double bouble wind screen i was thinking i might need a 42 or 43 rear with stock front but maybe not i am gonna pick up bike today will post new photo with new mods tonight tnks bobby c and zone head for advice i am not foolin around the bike was 12k mods so far 4k gear 2 k thats how bad i need to get into 200mph club
acapone72
BobC
posted April 14, 2008 06:29 AM
Those choices would leave you under-geared. With 17/42 you'd only get to 193 mph before the limiter cuts in and with 17/43 even worse at 189 mph.
As a rule of thumb: one tooth on the rear is about 5 mph either way and one tooth on the front is about 12 mph. (that's approximately, before I get flamed)
The standard 17/41 will only reach 198 before the engine rev limiter cuts it. So you'd have to go down one tooth at the rear, minimum, to reach a true 200.
Stock wheelbase
kspz3
posted April 15, 2008 12:15 PM
Last year I used 18/38 - will go to 18/37 this year..... that will do it in 5 gears on asphalt. complete with no wheel spin or wheelies in the launch. At Bonneville you need to allow for 4% to 8% wheel spin - so I hear....... but ask the experts to confirm. BTW - I have only made it to 192 before running out of track at Maxton - 187 and no more traction at Bonneville. 220lbs.
Kevin
kspz3
posted April 15, 2008 12:18 PM        Edited By: kspz3 on 15 Apr 2008 13:20
Using this figure:
The true engine rev limiter is 11,000 - dyno and acquistion proven. - but that number sounds right to me - give or take for tire wear....
BTW - Dragseat sucks for big men..... thin profile custom corbin and then stand on the pegs lifting up an inch or so in the saddle - no cawl is my conclusion..... but not definitive 80% certainty.
KSP
acapone72
08 zx14 blk n red
posted April 15, 2008 07:00 PM
well looks like i asked the right guys about gearing ill go 17/40 and see where i get with that will check corbin seat ran 160 today in a gusty cross wind on expressway i was able to get tucked in pretty good using the back a little and lay down position i think i shut down about the middle of fifth gear 700 miles on the ticker after afew more mods and miles ill get some dyno numbers thnks again
acapone72
flyboy
posted April 15, 2008 08:48 PM
If you guys are serious about going fast here is a great website to begin with:
http://www.gearingcommander.com/
Put in-- Kawasaki, Ninja, ZX-14.
"The World's Fastest Indian"
One fast red ZX-14,
halvefast
posted April 16, 2008 01:58 PM
Capone- What is your target Hp? You can reach 200mph with around 230-240hp.
I weigh 250 in gear, with 225Hp and 6% slippage I was able to go just 200. I believe you will need a bit more gearing though, my tire was spinning 212 on the 200pass.
I used 18-40 at 64" of length which hurt traction, bike and rider were 765lbs.
You can do it, give us some of your mods, did Ace do the motor?
If so he will make sure you go over for sure.
Best of luck hope to see you in Oct.!
ECTA Ohio Mile 195.132mph
Phantom13
posted April 16, 2008 02:42 PM        Edited By: Phantom13 on 16 Apr 2008 15:52
Whatever you do, make sure you bring different sprocket combo's. Weather conditions will effect your speed, this may change which combo is optimal.
P.S. - To get in the Maxton 200mph club, you need to break a record over 200mph. Unfortunately, simply going 200mph at Maxton does not get you in the club. Check out the ECTA website (www.ecta-lsr.com) to see what the record is in your class, this way you know what to shoot for. Good luck bro, hope to see you there!
"The only place Success comes
before Work is inside the Dictionary."
  Ignore this member    Click here to visit Phantom13's homepage.
kspz3
posted April 16, 2008 03:50 PM
Do it right and take it to the track........ Practice at drag strips - you will need to get to 150 in the quarter to have a prayer at 200 in the mile. Seriously - these kinds of speed are track only ventures - be responsible - be safe - have fun - and think about others as well as your self when making preparation for playing at speed.
Kevin
dutchzx14
posted April 20, 2008 08:50 AM
Hi Bob, how are you doing, your right, wasdoing 326km/h, with a good breeze in my back.but was was not on the red line yet.. today I hit the 314km/h, with 17/43, and 12000 rpm. we Changed the ref limiter with the ignition module from powercommander. al gps measured of course. the speedometer is a joke on this bike, 220km/h is on gps 200!!
300km/h is in real 270km/h....!!! (my spedohealer fixed that problem..)
NinjaNick
'08 ZX14 (Blue)
posted April 20, 2008 12:16 PM
I hit 175mph today. No traffic, so didn't have to worry about others. Me and my buddy on his '07 10r. I do it where it's clear and I want to.
Cajunboyz
posted April 20, 2008 01:34 PM        Edited By: Cajunboyz on 20 Apr 2008 16:40
Hey, dutchzx14, I new someone whom put on a ign module, he heard that when you use the rev extend part of the module that this makes an already good map LEANER & requires re tuning??? that is only when using the rev ext part .. Any more scoop behind this??
psaffrie
posted August 30, 2008 12:29 AM
Hello,
Can somebody tell me where to buy these sprockets? I'm looking for 39 rear just as Bobc wrote.
Kind regards from Holland,
Peter
  Ignore this member    Click here to visit psaffrie's homepage.
posted August 30, 2008 06:30 PM
schnitz racing
0.4787437915802 seconds processing time
