BIKELAND > FORUMS > ZX-14.com > Thread: Heat Resistant Foam NEW TOPIC NEW POLL POST REPLY
ghostman
posted August 26, 2008 01:53 PM
Heat Resistant Foam
Took my plastics off and noticed that some of the foam had separated from the plastic. Some had actually dry rotted.
What kind of adhesive do you fellas recommend to use to re-apply the foam?
I'm There Whether You See Me Or Not.
ghostman
posted August 26, 2008 04:39 PM
. . . . . . . . . .anyone?
BlackMagic14
posted August 26, 2008 04:43 PM
gorilla glue
posted August 26, 2008 05:19 PM
if you use real "heating /AC" duct tape, the metal stuff that has wire through it and costs a fortune, combined with some foam heat shield you'll have better insulation than the factory provided. at a cheaper cost than paying the parts man at the dealer for more cheesy foam to boot
posted August 26, 2008 05:54 PM
mmmmmmmmm cheesy foam
ghostman
posted August 26, 2008 06:19 PM
Doh!!!!!
smokinzx14
posted August 26, 2008 07:38 PM        Edited By: smokinzx14 on 26 Aug 2008 20:41
3M old yellow .......gorilla snot .... works everytime ....
ghostman
posted August 30, 2008 05:08 AM
Next question:
I have two pieces that fell off the bike while taking the plastics off.
Is there a reference that I could use to place them where they should be?
posted August 30, 2008 08:30 AM
there is if you didn't clean the old sticky stuff off!
Sticks_n_Stones
posted August 30, 2008 09:05 AM
Yea..... NO! Good luck with that, your best bests are: #1. Find another 14 in your area and talk him into taking his fairings off (good luck).
#2. post up the photos of the offending pieces and which side each came from and await an answer.
#3. Suck up enough to someone here for them to voluntarily go out to there bikes and takem apart and photo them.
Come to think of it, #3 is a good idea. I've probably spent at least a couple hours of my life trying to figure out where the hell those things go myself. So I volunteer the next guy to take his 14 apart to be responcible for the photos.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
smokinzx14
posted August 30, 2008 09:17 AM        Edited By: smokinzx14 on 30 Aug 2008 10:20
I think he is talking about the 3 parts that allways fall out when the body work is removed ...One goes around the coolant tank and the other goes around the lower rad hose to the water pump . The last one goes around the upper rad hose ..If that is the case they DO NOT glue in place ...You kind stuff them in place and put the body work back on to hold them in place..
posted August 30, 2008 09:53 AM
ohhhhhhh apologies....those pieces ARE a pain. the one around the water bottle I never replaced and never had a heat prob or vibrations regarding the fairing
ghostman
posted August 30, 2008 11:32 AM        Edited By: ghostman on 30 Aug 2008 12:32
Good lookin' out fellas!!!!
Smoke, Steve, that's exactly what I was looking for!!!!!
Sticks, I almost went there.LOL!!!
0.27664303779602 seconds processing time
