BIKELAND > FORUMS > ZX-14.com > Thread: THROTTLE STICKS WHEN COLD, WORKS FINE WHEN WARM NEW TOPIC NEW POLL POST REPLY
butta4hc
posted March 23, 2008 07:12 PM
I have a small concern about my throttle sticking when it's cold. If I goose it a few time while cold it will stick. Once it warms up it works fine. Has anyone had this same experience? I don't see it as a mojor concern but I need to know if it is a problem to be later on. FYI: This is my first bike with an electronic choke. all my other bikes where manual so I'm not used to it all this new technology, lol.
Butta
Hot Commodities MC
Paterson, NJ
2006 Black ZX-14 - Recall Frame Swap, Full Muzzy GP Exhaust, PCIII, BMC Race Filter, Flies Out, Braided Front Brake & Cutch Lines, Muzzy's Radiator Fan, Engine Ice Coolant, Frame Sliders, SubFrame Sliders, Puig Dark Smoke Windscreen, Powerbronze Hugger, Cox Radiator Guard, Unswitched Powerlet Outlet under seat, Switched Powerlet Outlet On Right Duct Panel, Intergrated Tail Light, HID lights high and low beam, Blue corner marker lights, Eclipse License Plate Blackout Kit, Black Pazzo Levers, Scorpio Alarm, Lojack Theft Recovery System, Rapid Transit Triple Tree Bag, Cortech Tank, Tail & Saddle Bags and the bragging rights for being "The Fastest 14 In The Country" for a few weeks when the 14 made it's debut here in the states.
  Ignore this member    Click here to visit butta4hc's homepage.
posted March 23, 2008 07:26 PM
the actual throttle handle does not return?
3boysand3bikes
One quick question... when you are, "goosing" it... are the handlebars all the way to the left, in the middle, or it doesn't matter which way they are turned.
I find it hard to believe that the throttle cable is 'sticking' since it is new(er). Especially when you mention that when the bike warms up it is fine. It almost sounds like you have a bit of a kink in the line when the bike is at rest... and when the choke is on, it allows the throttle to rev higher than normal... The set up might not have been done very well and your cable also may be a little too 'tight'.
On the other hand, if you have water in the throttle cable, it might also be the problem. There are many sprays that you can use to lube and clean the cable.
I am sure there will be a lot more input... but it is hard to tell without seeing the bike. Good Luck...
Jimmythesuperbiker
posted March 23, 2008 07:30 PM
seems like you have carbon build up around the butterflies
butta4hc
posted March 23, 2008 09:20 PM
Sometimes it doesn't not all the time.
Butta
Hot Commodities MC
Paterson, NJ
butta4hc
posted March 23, 2008 09:25 PM
Considering that it's usually on it's kickstand when warming I guess it/s always when it's full left. I might look into tha spray to see if that clear it up. If not I will be just ordering a new one to have the peace of mind.
Butta
Hot Commodities MC
Paterson, NJ
posted March 24, 2008 07:32 AM
If the cables are adjusted too tight, or routed incorrectly this can happen.
Rarely do throttles hang up due to friction between tube and bar these days in clean environments, and I have washed mine many many times with pressure washer, and ridden in below feezing temps, without the cables showing any sign of freezing up.
If someone has adjusted all the slack, and then some out of your cables, and then it hangs up when the bars are turned,,, cables adjusted to tight.
The bike idles high until warm too.
butta4hc
posted March 24, 2008 07:06 PM
Thanks for the info. I know that the electronic idle drops the idle when it warms up. The only thing I can honestly see is that there is a kink or the cable wasn't routed correctly at some point. I will just have to go through it to see. Does anyone just happen to have some pics of the proper routing? If not, I may have to hit the dealership for some answers.
Butta
Hot Commodities MC
Paterson, NJ
posted March 24, 2008 07:18 PM
mine are disconnected, and I run aftermarket clipons anyway.
0.26347708702087 seconds processing time
