BIKELAND > FORUMS > ZX-14.com > Thread: MPS No 5-6th with auto air shifter? NEW TOPIC NEW POLL POST REPLY
Cajunboyz
posted March 21, 2008 02:13 PM
I've been having my MPS auto air shifter on a 14 for about a year with no trouble. The bike has never been to the track,just roll ons top end running.My clutch is good & has shims on stock springs My shifter works fine from 1st to 5th automatically or button shifting, BUT it will now NOT shift from 5th to 6th automatically or using the button, Any ideas ?? it will foot shift fine ? I'm stumped??
Wheelie
Old Man
posted March 21, 2008 02:42 PM
lifetime warranty, call MPS.
wee
smokinzx14
posted March 21, 2008 04:38 PM
Add a little kill time.....
Cajunboyz
posted March 21, 2008 07:42 PM
Tried adding alot of kill, still the same thing, what if the clutch had a slight undectable slippage could this cause this since the motor is under a heavy load at redline & those speeds???
lietoome
posted March 21, 2008 09:09 PM
can you adjust the hardware/rod/piston up at all? I'm not familiar with the kit, but you may be able to solve it by moving it up a bit so it will slip into the final gear. Do you have good pressure? Do you you have pressure gauges on your bottle? Low pressure has done this to me, but it was in 4th gear.
If timing didn't fix it, I'd recheck the pressure and plumbing.
+1
posted March 21, 2008 09:27 PM
now, this is just hearsay, but I heard some guys had to get the shift drum cut...I think they had super short kill times though...
ask chip hunter what they were doing for his...
Cajunboyz
posted March 22, 2008 03:34 AM
Pressure is good Plumbing is good, I thank all for comments, just letting youll know what i tired thus far. I'm stumped, It will shift if i hold pressure on lever &slightly blip the throttle.
posted March 22, 2008 07:33 AM
is it going in, then poping out, like a false neutral, or just not leaving 5th, and grabbing 6th?.
sounds like forks or shift drum detent....
Cajunboyz
posted March 22, 2008 08:16 AM        Edited By: Cajunboyz on 22 Mar 2008 09:31
Its not shifting 5ht- 6th under a load at hi rpm using the shift button or auto shift. If i load the shifter with my foot & blip the throttle it goes right in?????
One of the only things i did is take the air solenoid valve out the loop(unplugged electr connection) & put a 22ohm resistor in its place???
Someone just said that in the manual that ; The 'air switching valve' is a 2-wire signal. You need a 3-wire sensor to have a code, is my observation reading the shop manual wire diagram.
Therefore, you will not code the switching valve because the one wire ties into the spark box, not the ECU. The other wire ties in with other wires that eventually run to a (relay) and eventually grounds to complete the circuit.
?????????? I'll try removing the resistor & see where that brings me
lietoome
posted March 23, 2008 05:49 AM
any luck yet?
Cajunboyz
posted March 23, 2008 06:24 AM
Yes & No, I have an igniton module on the 14, it seems to cause intermidate interfernce with the shifter system, I had also had a resistor pugged in where the air solenoid valve was which this wiring ties into the "SPARK' system, When i took the resistor out it worked on the button & auot shift, then i had some different problems.
posted March 23, 2008 07:32 AM
make sure the shifter is adjusted for full stroke travel, in all gears?
seems like the shifter must come up a little more for each taller gear, maybe its just not got enough travel to pull the lever up enough?
1badzx12r
posted March 23, 2008 08:46 AM
sometimes i get this bug on my zx14 but not just 6th but all gears are subject ...leaves me with a false sense of security ... pressure , travel, everything good then bamm everyting goes bad then it fixes itself ... i can't find problem either
posted March 23, 2008 10:53 AM
I put a little air tool oil in my line once in a while to keep the cylinder lubed....sticky cylinders suck, Oh and ran a 90degree fitting and 6 inch hose,on exhaust side to help keep dust ou of the ram when street riding.
Cajunboyz
posted April 01, 2008 08:03 AM
Does your shifter use an auto shiftbox(MPS)? Do you have any timing advancer plate or ign module on the bike???
0.27241110801697 seconds processing time
