BIKELAND > FORUMS > ZX-14.com > Thread: gear ? NEW TOPIC NEW POLL POST REPLY
realn07
posted March 31, 2008 10:15 PM
gear ?
just wondering what type of gear i should run for the 1/8. only mods i have are strap, muzzy ss full exhaust, flies out, pc, stock wheel base. should i leave it stock gear till i streatch it or go up or down in front or rear. oh i weigh 230 unsuited. need more out the hole grunt but dont wanna lose too much on the big end. thanks.
00Busa
Trying to go FASTER !
posted April 01, 2008 02:43 AM
I went down 1 (16) in the front and up 1 (42) and I weigh 175 lbs. You need at minimum to go down 1 in the front and 42 maybe 43 on the rear if you can keep it down.
'00 Busa / '06 14 /
IT AINT BRAGGING, IF YOU CAN BACK IT UP !
realn07
posted April 01, 2008 06:29 AM
how do you think just going down 1 in the front for now would do.
00Busa
posted April 01, 2008 07:25 AM
It will definitely help, after that you can play around with the rear. Make sure you have a GOOD impact when taking the front sprocket off or you'll kill A LOT of time trying !!!
'00 Busa / '06 14 /
0.26167416572571 seconds processing time
