BIKELAND > FORUMS > ZX-14.com > Thread: CAM CHAIN TENSIONER NEW TOPIC NEW POLL POST REPLY
zx14srule
new guy
posted February 12, 2008 04:11 AM
CAM CHAIN TENSIONER
I WAS WONDERING IF A 2008 ZX14 CAM CHAIN TENSIONER WOULD WORK ON AN 06-07 MODEL ZX14, I HEARD THAT THE 08 TENSIONER IS REVISED FOR THE NEW BIKES.
zxbob
posted February 12, 2008 05:01 AM
Yes it will.
Bob
billeason
posted February 12, 2008 06:05 AM
I have been using them, I use to mod the 12 adj, but they got hard to get once it got out that they worked on the 14s, The 08 tensioner are bolt on's, They still don't work as well as the modified units, bill.....
bill eason
87gtNOS
posted February 12, 2008 09:54 AM
What's the part number for the 08 tensioner?
Does anyone care to share the procedure for the swap? Simple bolt-in?
01 ZX12R
2002 ZX12
2002 zx12
posted February 12, 2008 12:53 PM
What kind of mod did do to the zx12 tensioner to work on the zx14
Cajunboyz
posted February 12, 2008 02:18 PM
A Good guy on here,billieason along with Carpenter told me that the ZX-12 tensioner fits, but its a little shorter,. All they do is remove.120 thousanths from the face of the 12 tensioner where it bolts to the head,this allows it to be the same lenght as the 14's & not be shorter on total lenght.
johnsonzx14
posted February 12, 2008 03:14 PM
what does this help with?
87gtNOS
posted February 12, 2008 03:36 PM
KNOCKITEE-KNOCK-KNOCK
01 ZX12R
billeason
posted February 12, 2008 04:22 PM
Hey 87, The old p# was 12048-0034 for the 06-07. The update p# 12048-0048 is for the 08. it is a direct bolt on. Price retail is $79.68. Its worth it' even more so with a motor that has some work done and rev's a little quicker. bill....
bill eason
87gtNOS
posted February 12, 2008 04:25 PM
So unbolt the old one and insert the new one?
Thanks eh!!
01 ZX12R
billeason
posted February 12, 2008 05:28 PM
tensioner
Thanks eh!!
You got it, slap a little oil on the oring,torgue it down and ride. I get my parts from clem at osr if i need too. I'M not saying there isn't other guys on here that can get you hooked up but osr is into drag racing, so lots of info there. bill...
bill eason
ninja14
posted February 12, 2008 06:48 PM
APE manual:
2006 Turbo ZX-14.
2005 V-max 20th Anniv.
mikebar4
posted February 12, 2008 08:13 PM
the one APE makes works perfect and its only about 45 bucks
ninja12
posted February 12, 2008 08:38 PM
The manual is nice IF you know how to keep it adjusted, if not engine damage can occur.
The rest of us need the " set it and forget it" of OEM.
ninja14
posted February 12, 2008 09:19 PM        Edited By: ninja14 on 12 Feb 2008 21:19
Ya don't even have to set the stocker - can't get any easier than that ..............
2006 Turbo ZX-14.
87gtNOS
posted May 14, 2008 08:16 AM
hoping Billeason will see my other thread about the new tensioner!!!
01 ZX12R
davej
posted May 14, 2008 10:28 AM
After the 14 warms up to 2-3 bars and sits for say about 10 minutes and restarts I can hear the tensioner take up the chain slack but sometimes for about 10 seconds can still hear a knock. It doesn't happen all the time though, could it be piston skirt slap or just the nature of this type of tensioner? 14,300 miles. Noise is coming from the right side of engine same place as the camchain.
Triumph guy
Nelson Taylor
posted May 14, 2008 11:20 AM
Thats the same noise thats been hunting me.
Anyone know what changes were made with the 08 tensioner to eliminate this noise.
I assume this thing adjust itself once oil pressure builds, Am I correct?
Is the long term effect of this, these bikes needing new cam chains.
Best #'s
1.54
4.03
6.02 @ 121mph
(Stock Wheelbase) 2006 ZX14
davej
posted May 15, 2008 04:04 PM
Got the knock again after 20 min stop 3 bars at stop. Shut the engine off and restarted, knock cleared instantly. Probably have a sticking tensioner that reset after releasing the oil pressure. Anyone else notice this?
Triumph guy
Burnoutzx14
Stretched/Lowered/NOS
posted May 19, 2008 06:22 AM
Mine is exactly the same.. And cold start up its even worse, All my buddys give me shit because of the rattling.. So from what i,v been reading here a stock 08 replacment will cure my Chain rattle??
rOck oN!
  Ignore this member    Click here to visit Burnoutzx14's homepage.
Nelson Taylor
posted May 19, 2008 07:41 AM
There should be a recall on this or Kawasaki needs to put out some info on how to correct it to prevent damage.
Best #'s
1.54
4.03
6.02 @ 121mph
Sticks_n_Stones
posted May 19, 2008 08:37 AM
Alright fellas, I'm wondering if thats what I'm feeling in my footpegs. Since new, I've always had a odd knocking going on that is mostly felt in my left footpeg, only notice it when I'm riding. Similar to if something was loose in my rear suspension and knocking every time I hit a bump, but it seems to have no correlation to any movements of the suspension, rpm, or speed.
I've adjusted my chain 3 times now, and the last time I even overtightened it to make sure. Knocking still there. Think it could be the tensioner?
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
davej
posted May 19, 2008 09:48 AM
Had the same knock over bumps since day one, improves with chain adjust.
Triumph guy
Sticks_n_Stones
posted May 19, 2008 10:17 AM
No luck, tried that. Even with the chain TIGHT it made the exact same knocking sounds. I'm going to lower it on my Muzzy lowering links and see if that helps, at least it should completely rule out the chain as the cause because it will raise the rear sprocket and pull the chain off the plastic swingarm guard (hopefully at least).
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
davej
posted May 19, 2008 10:40 AM
I'm running on the middle setting with a Muzzy link since 2000 miles. Could it be the shock fully extending? First noticed it on the Salt Flats where the off track road was really bumpy. Caliper rattle could be another cause, very common with automobiles.
Triumph guy
0.31946015357971 seconds processing time
