BIKELAND > FORUMS > ZX-14.com > Thread: anti smog removal NEW TOPIC NEW POLL POST REPLY
starchild
posted February 02, 2008 09:44 AM
anti smog removal
tried a search for this did not work, has anyone removed the kleen air system? and does anyone have pics to show the procedure? want to remove it from the 14. is it the same as the 12? easier or more difficult?
jay
FASTESTbusaAROUND
I eat Fish...
posted February 02, 2008 09:50 AM
Just have to use the block off plates; no need to remove anything. I didn't find that the block offs made any difference in the popping either though. It did on my Busa's, but not really on the ZX14.
FYYFF!!!
starchild
posted February 02, 2008 11:05 AM
not concerned with popping trying to gain any horsepower i can and from what i hear there is more to removing the kleen air on the 14 than the 12 , thanks busa
jay
2002 Zx12
2002 zx12
posted February 02, 2008 05:05 PM        Edited By: 2002 Zx12 on 2 Feb 2008 17:07
Not hard to take off but is hard to get at just takes a little time do not belive there is a horsepower gain some weight saving and if you need to get in that area to work on something like change the plugs makes thing a little easier I took the pump off and the factory plates like stated above does not help the poping only advantage I see is for getting to the area a little easier. Also have been told to get a true air/Fuel reading off of a dyno this should be unhooked.
starchild
posted February 02, 2008 05:21 PM
yea that is what i was hoping to hear i'll start tommorrow thanks 2002
jay
kawabunga
Cogswell Cogs Installed
posted February 02, 2008 06:31 PM        Edited By: kawabunga on 2 Feb 2008 18:36
When you remove the kleen air system you should always plug the hole in the bottom right side of the air box, ( where the large hose goes into the rubber grommet. DO NOT LEAVE OPEN...this will deffinately make it pop. Plugging the hole reduces or eliminates the popping all together, provided your PC is mapped correctly. I recommend pulling the hose out, cut off to about 3" long, plug one end of it, then sick it back into the grommet with about 1.5" hanging out. Or if you can locate a plug the size of the hole with grommet removed use it.
0.2750678062439 seconds processing time
