Sigma14
posted November 04, 2007 12:46 PM
ZX14 Rear Fender Removal
How difficult is it to remove the rear fender?
BlackMagic14
posted November 04, 2007 01:17 PM
EASY!!! 4 botls and 1 wire took me maqybe 7 or 8 minutes
ninja14
posted November 04, 2007 01:19 PM
Unless you have trouble removing the toolbox............
2006 Turbo ZX-14.
2005 V-max 20th Anniv.
pdonnell
posted November 04, 2007 02:55 PM
Hardly 8 or 9 minutes. Gotta lift the gas tank, remove the tool tray, disconnect the ECU, remove the transistor and tail light assembly. Then you can remove the rear fender. All that stuff under your seat has to get disconnected first. Then you can remove the fender. I'm doing mine to remove the rear sub-frame for powder coating. Just going off the shop manual.
smokinzx14
posted November 04, 2007 02:59 PM
quote: Hardly 8 or 9 minutes. Gotta lift the gas tank, remove the tool tray, disconnect the ECU, remove the transistor and tail light assembly. Then you can remove the rear fender. All that stuff under your seat has to get disconnected first. Then you can remove the fender. I'm doing mine to remove the rear sub-frame for powder coating. Just going off the shop manual.
I think he is talking mud flap.....
mink
posted November 04, 2007 07:24 PM
i can pull all the body work and the rear sub frame in 8 or 9 minutes
pdonnell
posted November 04, 2007 09:48 PM
Mink,
You da man
BlackMagic14
posted November 04, 2007 10:11 PM
Yeah I am assuming that he is talking the mudflap. Dont know why you would liftthe gas tank LOL
reckless
posted November 04, 2007 10:41 PM
Hmmm, lets see. I removed the stock fender on my 14 Saturday night to install a Muzzy fender eliminator. You don't need to disconnect anything but the light for the plate, (small 2 wire connector under the seat)
1. remove the seat (use the key)
2. open the tool kit, take out the tools, unscrew the 4 bolts holding the tool box to the bike and remove it (you will need to remove the small module that is attached to a bracket on the tool box, use a straight blade screwdriver to unlip it)
3. lift the ECU out of the tail section and move it over to the left side of the bike (it sits on one or two metal brackets with rubber mounts, pulls staight up)
4. undo the 3 nuts that hold the fender assembly to the bike, the front two have captive bolts, the rear requires you to reach under the fender and hold the head of the bolt.
5. unplug the license plate light and feed the wire through the hole.
That's it. mount your fender eliminator of choice (follow the companies instructions) and then replace what you moved out of the way. Don't disconnect the ECU or remove the gas tank unless you have an overwhelming desire to make a 10 minute job much more complicated than it is.
BobC
posted November 05, 2007 12:48 AM
Edited By: BobC on 5 Nov 2007 00:49
Aren't the bolts securing the tool tray fitted with tamper proof nuts? Seem to remember I had a job removing them, used a pair of grips in the end.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
ZXGRIFF
posted November 05, 2007 03:57 AM
Metric hex key on mine.
Sigma14
posted November 05, 2007 05:28 AM
Thanks everyone!!!
pdonnell
posted November 06, 2007 06:43 AM
Edited By: pdonnell on 6 Nov 2007 06:48
Shop manual calls the license plate holder the license plate holder. The fender is what the license plate holder is attached to. A hugger isn't a fender either, its a hugger.
The question referred to the "fender", not the license plate holder. I know its hard for people that can't read a shop manual but the fender did require the gas tank to be detached and raised to be removed. That big piece of plastic under your seat with all the electronics and tools attached, that sits right above your rear wheel (or hugger) is the fender.
And yes the license plate mount is very easily detachable in under 8 minutes. Tack on a few more hours to remove the fender and rear sub-frame.
