BIKELAND > FORUMS > ZX-14.com > Thread: Ohlins rear shock NEW TOPIC NEW POLL POST REPLY
jarhead
posted September 30, 2007 11:50 PM
Ohlins rear shock
Just wanted to know if anyone has an Ohlins rear dragshock? I am curious if it is worth the money. I had Trac rework the shock on my 04 zx10 and I think I was robbed, I could tell no difference at all. I am at 64"wb and spraying a 50hp dry shot that doesn't come on until WOT. I am 160 lbs is gym shorts and -1 in front. I seem to have traction issues more than most guys, by that I mean I am the first to know when the track is going away. Oh yeah, 200 Shinko 003 ultra on the rear. I am also thinking of gearing differently, maybe go back to stock in front and up on the rear but I am thinking that might make the problem worse. Anyway, any input would be appreciated.
posted October 01, 2007 07:09 PM        Edited By: dubious on 1 Oct 2007 20:33
I love my ohlins... between remote preload adjuster, adjustable length, adjustable links, clickers that really adjust the damping curves, and adjusting tire pressure... if there is any traction to be had, you have the tools to find it...
I run my 6" arm at 5" over, and it hooks pretty decent ... Just make sure you order the right spring rate for the additional leverage the arm has on it.
Here's some pics..
http://www.bikeland.org/board/viewthread.php?FID=27&TID=34555&set_time=
I don't have it slammed cause i ride the streets, and they are really rough around here...
I like corners too!
posted October 01, 2007 07:13 PM
A leaf spring from the back of a CJ Jeep would perform better than the plush factory ZX14 shock. I bet you do love the Ohlins!
0.25648498535156 seconds processing time
