BIKELAND > FORUMS > ZX-14.com > Thread: setup for extensions NEW TOPIC NEW POLL POST REPLY
blackbullet76
posted August 27, 2007 05:57 AM        Edited By: blackbullet76 on 27 Aug 2007 07:02
Ok, I think I'm ready to put some extensions on my 14. What length are you guys running? I can get the 4" to 9" extensions, but don't know how far back to set the wheel. On my friends R1, we set it back an extra 8 inches, but the 14 has a longer wheelbase from the factory than the R1. Also, can I drop it down 3 inches when its stretched for the track without it bottoming out? I know on my friends R1, his rear spring got softer when we stretched it. I would appreciate any help. I just don't want any surprises when I go to do this. Also, I thought about going bigger on the rear sprocket too. I'm runnig a 16t on the front right now. I thought about going to a 43 or 44 tooth in the rear. All of this will be for the track, I will put it back to stock length when on the street. I'm going to get master links for the stock chain and the chain I use for the extensions (2 separate chains, one for street one for track).
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
blackbullet76
posted August 28, 2007 05:44 AM
Anyone?
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
Bishopzx12
posted August 28, 2007 06:32 AM
I recently had mine added and i have not had a chance to make it to the strip. I am geared 16/43. I am about 7 inches now but on my 12 i am about 6. I would pronanly start anywhere from 4-6. If you are going to be a straight track guy you make want to start at 6. I have had a little problem and have seen many other guys have a lot of problem with traction for hole shots in the street with excessively long arms
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2002 GSXR 1000 "I was Drunk"
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
smokinzx14
posted August 28, 2007 06:54 AM
Start off with 62 inches.. That is about 5 inches over ...That worked good for me.....
blackbullet76
posted August 28, 2007 08:11 AM        Edited By: blackbullet76 on 28 Aug 2007 09:12
Ok, thanks guys. I'll get the 9 inch extensions and set it back 5 or 6. Wil the 3 inch drop be ok though or will I be safer at the middle hole?
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
Bishopzx12
posted August 28, 2007 10:37 AM
Brother it depends in you ride fat chicks on the back.lol Mine is fine and i weigh 280. its a little rough around town dodging the pot holes though
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
kc jr 54
Fat Guy
posted August 28, 2007 10:43 AM
Go with the middle hole IMO.
Wheelie
Old Man
posted August 28, 2007 02:26 PM
if you weigh around 200, 5 inches will still wheelie when launching hard, you will be adding links. If your a fly weight like Smokin, you will be less wheelie prone. btw Smokin, dont tell us you weigh 160, hehehe. weeeeeee
blackbullet76
posted August 28, 2007 03:42 PM
I weigh 200 lbs. How far do I need to go back? Remember this setup is for the track only. I will raise it back up and take out the extensions for street riding.
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
Wheelie
Old Man
posted August 28, 2007 03:45 PM
mine is at 64" and it still wheelies, im at 205lbs + gear. wee
smokinzx14
posted August 28, 2007 03:54 PM
I don't think weight has much to do with it .... I have wheelied at 68 inches but my bike seems to ET better at 62 inches than 68 ..... Oh thats at 150 pounds ....lol..
jdzx14
posted August 28, 2007 04:00 PM
This might be a dumb question but, where are you guys measuring from to get 62, or 64 inches? I am extended about 5 inches and have been wondering the whole length.
2007 Black ZX-14
Bently
2012 14r In Blue and no Mods!
posted August 28, 2007 04:36 PM
I was at 62.5 inches and wheelies were not a problem as long as you know how to launch, it takes practice. I wheelied a zx 12 that was 8 over saturday so anything can be wheelied. My best 60 ft at 62.5 was 1.44. you go back much farther then that and unless you are on a really well preped track you will have traction issues.
Nelson Taylor
posted August 28, 2007 07:21 PM
Axle to axle gives you the length of wheelbase.
BlackMagic14
posted August 28, 2007 07:48 PM
Nelson is correct measure it axle to axlt, what I do is have someone hold the bike up straight make a chalk line on the pavement where the axle is and then measure the distance between the chalk lines I am 280 pounds at 64 inches and NEVER have a wheelie problem or traction problems I think 63-64 is perfect, I think 62 is a little short (not everyone can ride like smokin)
blackbullet76
posted August 30, 2007 09:47 AM
I just ordered everything. I'm going staurday morning to pick it all up. I'm gonna try a 7 inch stretch with 16/44 sprockets. Should be fast
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
0.22072005271912 seconds processing time
