BIKELAND > FORUMS > ZX-14.com > Thread: 1534 NEW TOPIC NEW POLL POST REPLY
Bishopzx12
posted August 28, 2007 06:46 AM
1534
Hey what up with the 14 stroker motor and big bore kits. I have yet to see anyone to post any real number or for the most part talk about it except muzzy and carpenter. I mean schnitz use to carry the muzzy kit it on there web page but dropped it some time ago for what reason if anyone knows please share it. Ryan if you could please let me and the board know also it would be great info. I was also wondering why hasn't any of the big names such as JE or WISECO developed a kit yet. JE are advertising the same bore as muzzy a 2mm. They usually differ from muzzy by 1mm or .5mm in bore size like the 1270 of muzzy and 1290 kits of JE and ape for zx12. Where are the big bore kits guys. When the zx12 came out there were so many guys beggin for more and installing the 1270 that you could shake a stick at. How realiable will the strokers be? Will the motor be as finiky with a crank as my 1375? I ask becasue i have been saving and its getting closer to fall and i am go to venture into this uncharted land.Wanted to get some head up. Really thinking of going muzzy. its seems to be a reasonable price.
A. Special head gasket.
B. Special 86mm 13/5.1 Muzzy pistons.
C. Special high speed rings.
D. C-clips.
E. Piston pins.
G. 5mm stroker crankshaft.
All for only $1699.95 with your crankshaft core, or add $695.00 with out.
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2002 GSXR 1000 "I was Drunk"
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
smokinzx14
posted August 28, 2007 06:50 AM
Might want to add some extra cash for a good set of rods with that package ....Better to be safe than sorry ....Smokin...
Bishopzx12
posted August 28, 2007 09:00 AM
Smokin i have ondered on that but i guess i was trying to get some info from the board on the kits out there and why have not anyone jumped on one.The 14 has been out about 18 months and not one have i hear d about being heavily modified except Rickys. I mean ggiy like mean and you have tried nitrous and other things but no real;ly big engine mods
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
posted August 28, 2007 11:25 AM
I talked to some people at Carpenter and orient almost a year ago now...
Can't remember the price exactly so I won't quote it, they did however mention 220-230 RWHP stroked , bored, cammed, ported and race fuel....
bishopzx12
posted August 28, 2007 12:09 PM
I am thinknig of ordering the muzzy pistons now since i have the money but ws just waiting to see what guys had in mine. to me it seem to just do a 2mm bore would be a waist of money compared to hp gain.
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
posted August 28, 2007 09:02 PM        Edited By: dubious on 28 Aug 2007 22:03
Personally, I wouldn't even bother with bore.
Just stroked, headwork, rods, pistons and cams...
The cylinder walls are so thin these days ..., hot spots, uneven expansion, scuffed walls etc... not enticing to me... especially cause you cant change just the jugs if does go wrong!
Anyone running big bores on big juice, or turbo seems to run into cylinder issues sooner than later.
bishopzx12
posted August 29, 2007 03:46 AM
Dubious not sure what you meant by Just stroked, headwork, rods, pistons and cams... are you suggesting stroke the stock crank and leave stock piston in.
What type of hp gains would that yield. I wonder if anyone ever done that on a 14 or 12 for that matter. Maybe stock bore aftermarket pistons,stroked, headwork, rods, and cams. Should be able to hold a good 70-100 shot wet and see maybe 15hp from the stroke, headwork, rods, and cams plus maybe 10-15ft/lb of more torque.
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
blackbullet76
posted August 29, 2007 04:34 AM
There's a guy at our track running the 5mm stroker crank. It's a mean sounding bike. He's running a 5.69 @ 125 in the 1/8. I believe he's spinning a little off the line too.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
posted August 29, 2007 04:50 AM        Edited By: dubious on 29 Aug 2007 05:52
read it again bro....
Stroked, headwork, rods pistons and cams...
Not stock pistons, but not bored either!...
I have long been an advocate of stroking rather than boring, especially on an engiine like the 14 which is already oversquare...
A 2 mm stroke will yeild much larger compareable gains than bore all else being equal.
Thats not to say the stock pistons are suitable, but... the bore is!
Besides, I would not have to send the cases out for boring and replate!
Chip Hunter is one fine example who has not done the bore, but has done the crank....
bishopzx12
posted August 29, 2007 06:09 AM
Hey dubious break it down with me, what did you mean by pistons then, afternarket with stock bore. I am confused
sorry bro
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
posted August 29, 2007 06:27 AM
Yup, JE makes stock bore high compression pistons...
bishopzx12
posted August 29, 2007 07:20 AM
So i take i take those JE pistons. Maybe do a 2mm stoke get the head ported.some cams and a valve spring kit and i am in the game.. With that in mine i should be able to shoot a little more than a 50 shot dry or maybe even go wet.
What number s have Chip seen
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
nightmare
ACP Racing
posted August 30, 2007 05:23 AM
Chip has a thing on the board talking about his numbers dawg! He is in the low 8s right now and one of them was off a 1.5 60ft. Nice numbers. Be back in a week too. Got to get together at the track. A guy name raymond wants to test me on his CBR900 with a 1000rr motor and some gas!
2006 ZX14 Ninja "SWINE FLU"
60ft 1.23
8th Mile 5.16
ACP Racing
bishopzx12
posted August 30, 2007 08:38 AM
Welli am betting with ya. Me and Mr clean are suppose to go to the track saturday night and sunday after noon. so i plan to get a lot of seat time in this weekend
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
nightmare
ACP Racing
posted August 30, 2007 09:52 AM
Cool! Clean told me he got another guy riding his bike that got him in the 5s. So I'm going to see what's popping on him and I locking up and letting them fly!
60ft 1.23
8th Mile 5.16
ACP Racing
0.22059416770935 seconds processing time
