BIKELAND > FORUMS > ZX-14.com > Thread: cooling problem solved..!! NEW TOPIC NEW POLL POST REPLY
dutchzx14
posted August 26, 2007 02:41 AM
Took the fenders off and looked in the radiator, and saw no liquid at all... bet the 200 mph runs causes allot of cooling liquid to spil.... In combination with the higher compression I'm running. running fine again..
  Ignore this member    Click here to visit dutchzx14's homepage.
posted August 26, 2007 04:06 AM
No to rain on your parade, but better safe than sorry...
I have ran mine at top speed many many many times, almost every day I ride it
and have never had that issue.
Have you checked the thermostat? The rad should suck the level back out of the rad while the bike cools.
A coolant pressure test when the engine is still hot would be ideal.
If it were my bike I would be concerned about the headgasket.
Sometimes they will leak just enough under combustion pressure (increased compression) to push the coolant into the resevoir, but will not suck any into the cylinders.
This is why many will o-ring the head gasket when they bump compression or go turbo/supercharger.
dutchzx14
posted August 26, 2007 08:27 AM
Dubious was optimistic to early.....it's a blown gasket..... hear air bubling in the radiator, and the resevoir stays full after it cooled down...... bring it to my tuner this week..
posted August 26, 2007 08:40 AM
sorry to hear that, but at least you got it pegged. dubious your reasoning was sound.
dutchzx14
posted August 26, 2007 10:07 AM
called the tuner, and no problem at all. gonna fix the trouble, and he hase to find a solution for this problem also, otherwise i'll be on his front door a few weeks later with the same problem...
posted August 26, 2007 10:59 AM
Sorry to hear that, but was afraid so...
I have decked many heads and cylinders in my days..
How much did he cut off?
dutchzx14
posted August 26, 2007 11:51 AM
Don't really know dubious... will ask him this week... on heineken right now ,to forget this shit........ lol.
hotzxrod
posted August 26, 2007 02:27 PM
is heineken the official beer of zx-14.com? i say yes. do we have a second to pass it to law
tilthewheelsfalloff
  Ignore this member    Click here to visit hotzxrod's homepage. Click here to send hotzxrod an AIM message.
posted August 26, 2007 02:32 PM
If the machinist did the work right, and everything was properly torqued, then there are other issues at hand....
Better get him to order some cylinder head studs from Schnitz, orient , APE or what have you... looks like you found the limit of the stockers...
Along with decking heads and blocks, i also have stretched many head studs!
All part of the game!
FasterThanStink
posted August 26, 2007 02:59 PM
I second the motion!
That's what gets you.
BobC
posted August 27, 2007 06:55 AM        Edited By: BobC on 27 Aug 2007 07:56
Sorry to hear that it's the head gasket after all. Were you going to JD11 if the bike is ready in time?
I doubt if I can make it now as GT Motorcycles is moving shops and time is just too precious.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
0.3807590007782 seconds processing time
