BIKELAND > FORUMS > ZX-14.com > Thread: Lower suspension link NEW TOPIC NEW POLL POST REPLY
stu64
posted July 29, 2007 10:11 AM
Hey guys what does this suspension link do?
http://secure.mycart.net/catalogs/catalog.asp?prodid=4942958&showprevnext=1
BlackMagic14
posted July 29, 2007 10:16 AM
it really helps traction and you can lower your bike more
posted July 29, 2007 10:18 AM
the one on Brock's site works better :P
stu64
posted July 29, 2007 12:14 PM
I don't see one on Brocks site?
mark524
posted July 29, 2007 01:16 PM
I've been looking at this too. I'm lowered all the way, but having problems with the tire hitting the inner fender. Will this help? I already have a heavier spring and it's not enough.
ZXLNT
posted July 29, 2007 02:10 PM
No mark it wont help, if you tire is hitting, your tire is hitting plain and simple. Only way would be to remove the inner found giving more clearance up underneath.
mark524
posted July 29, 2007 02:17 PM
from what I understand, these make the suspension alot stiffer? Making the spring you have act like a stiffer one. This would solve my problem. It only hits when I'm launching at the track.
flatoutbu
posted July 29, 2007 07:36 PM
I have one on my bike and they work. It does stiffen your shock back up and you will not need a stiffer spring. I had to put the stock spring back on mine because it was waaay to stiff with the trac spring i had....well worth the money.
06 Blue 14
9.008 at 153mph @ 195 suited
mark524
posted July 29, 2007 07:44 PM
now is yours a fixed one or is it adjustable like the link pro. I was going to get the one from the guy that sells them on Psychobike.
stu64
posted July 30, 2007 03:00 AM
This is the kind of info i was looking for.
Mark keep us posted about the link that sells on pyschobike.
Cost and who sells it.
flatoutbu
posted July 30, 2007 06:30 AM
That's Zook/Anthony. His house just burned down 2 weeks ago. I think it's going to be awhile before he gets back on his feet. Mine was made by him also. I used the stock dogbones and had to grind small notchs in them but they work great. Also had to do alittle hand filing to get the link to fit perfect...nothing major...just anal.
06 Blue 14
mark524
posted July 30, 2007 07:07 AM
I just ordered mine from Zook. Do you have any tips or tricks to getting the bearings out of the stock link? Maybe a proper size socket would knock them out.
flatoutbu
posted July 30, 2007 12:25 PM
Thats what i did with mine...being very careful and used a rubber hammer. I'm glad he's still up and running. You will have to make or reuse your stock dogbones.
06 Blue 14
stu64
posted July 30, 2007 02:34 PM
Link? ordering info?
stu64
posted July 30, 2007 03:25 PM
Any chance ZOOK will be making a ZX14 oil pan? His Busa pan prices are decent and affordable.
posted July 30, 2007 10:08 PM
Wow the dudes house burned down man..... oil pans... give the guy a break! LOL
flatoutbu
posted July 31, 2007 06:40 AM
I know he does all his machine work at his buddies shop. You'll have to ask him about the pans but i'm thinking that's more of a CNC type of deal instead of doing it by hand. He's on psychobike all the time.....he's one of the board sponsors.
06 Blue 14
mark524
posted August 04, 2007 10:08 AM
Just thought I would share my experience with the straight link.
Suspension setup before
650 lb. Race tech spring, preload all the way down, lowered all the way with 3-hole links. Still rubbing inner fender on launch w/290 lb. rider. Stock wheelbase.
Yesterday, I installed the straight link from Zook, changed back to the stock spring and installed extensions. Wheelbase is now around 63-64". I didn't know how much stiffer it would get with the straight link, so I cranked the preload all the way down on the stock spring.
The 3-hole lowering links are too long for the straight link, so I used the factory links. Slight grinding was required to make them fit. Ride height came out somewhere between the middle and lowest setting on 3-hole links. What really suprised me was after cranking the stock spring so tight, it barely moved when I sat on it! This was good, because everything else I tried resulted in still too soft. Loosened up the preload some and I'm pretty close to where I want to be. No more hitting the fender.
Hopefully someone will find this info helpful.
flatoutbu
posted August 04, 2007 05:35 PM
+1 on everything ya said.....i had the same experance....you'll like it.
06 Blue 14
stu64
posted August 09, 2007 05:03 PM
Does the lower wing fairing still fit with the link?
mark524
posted August 09, 2007 08:40 PM
yeah, I've still got mine on
stu64
posted August 19, 2007 12:23 PM
Started to put mine on, i see what you mean about the links not fitting,will take to work tomorrow and have some machined off the sides.
Did anyone just cut off those frame tabs that are for the centerstand instead?
Also is anyone bottoming out against their fuel pump? Stu.
0.27643799781799 seconds processing time
