BIKELAND > FORUMS > ZX-14.com > Thread: ZX-10 question NEW TOPIC NEW POLL POST REPLY
kawiguy3
posted June 08, 2007 05:58 AM
ZX-10 question
I know this is a 14 section but i know like me alot of you guys own a 10 to, and have asked alot of questions over here, i like and respect alot of you guys. i also posted it in the 10 section. so here we go
its an 06 with 3000 miles on it. pulled away from a stop really easy shifted into 2nd fine, and then nothing. i have tried everything i can think of, the linkage and everything is fine there is still spring tension both up and down on the shifter. its like one of the pins on the shift drum broke, or the fork thing that rotates the shift drum broke or fell off?? any ideas
(BTW i dident search on this.... i hate that search thing)
heros will never be forgotton, but legends never die
blackbullet76
posted June 08, 2007 10:54 AM
You still got a warranty on the bike? If not, you might be looking at alot of work.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
Tool man
posted June 08, 2007 11:02 AM
Sounds about right, can you shift up or down or nutt'n at all?
The banks are failing..
The banks are failing...
Invest in Ammo
kawiguy3
posted June 08, 2007 11:26 AM
it wont shift at all, but the shift lever will move freely.
and yea its warranty issue
blackbullet76
posted June 08, 2007 11:33 AM
I'm not familiar with a bikes shift drum and forks, but if it's anything like a 4-wheeler set-up, you have to split the case to get to it. I'd lake it to kawi and let them worry about it.
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
posted June 08, 2007 11:35 AM
sounds like the shift shaft is broken.
Forks usually bend, but will enguage in one direction still.
kawiguy3
posted June 08, 2007 12:07 PM
if it was shaft i would lose the spring return wouldent i??
0.23690390586853 seconds processing time
