BIKELAND > FORUMS > ZX-14.com > Thread: dyna shift light NEW TOPIC NEW POLL POST REPLY
jdrill04
posted June 06, 2007 04:29 AM
dyna shift light
I was wondering if anyone that is running muzzy airshifter , ever got the dyna shift light to work right . I have tried tying into the white wire with red tracer on the leftside coil. now i have been told you have to use two coils to get the correct signal. that one only picks up half the signal.
smokinzx14
posted June 06, 2007 07:03 AM
Maybe you got the wrong unit ?? I have mine hooked to the white with red tracer and it works fine ... But a friend ordered one and it had a different part number and he had to wire it to two coils to make it work....
jdrill04
posted June 06, 2007 08:59 AM
yeah , i talked to them at schnitz . they told me to hook it to two coils . thanks alot smokin
smithabusa
posted June 08, 2007 10:34 AM
If you have the wrong number of pulses per rev you should be able to double or cut in half your RPM setting and get it to work.
  Ignore this member    Click here to visit smithabusa's homepage.
0.269455909729 seconds processing time
