BIKELAND > FORUMS > ZX-14.com > Thread: Muzzy airshifter issue........sorta. NEW TOPIC NEW POLL POST REPLY
Brent Davis
posted May 09, 2007 03:29 AM
Guys, I installed this shifter and from day one, had no issues at all..........until Monday when it started to lock up the transmission. I would put the bike in first gear and then it would flicker and show Neutral. I then would just normal ride the bike and it would shift 1-2, sometime 3 and none in 4-5-6. I took the shifter cylinder completely off and the bike shifts and runs just fine. I checked again for binding with the shifter on the shift fork but it free moves and has no binding like it did when I had to trim some of the shifter down.
Any ideas? Thanks in advance.
lietoome
posted May 09, 2007 03:35 AM        Edited By: lietoome on 9 May 2007 06:38
someone had to bend the shifter or shifter rod, but I'm not sure if it was a muzzy kit or not. Please keep us posted.
iflyems
posted May 09, 2007 06:30 AM
Had the same problem, and it was never resolved. Sent it back to Muzzy and they couldn't reproduce the problem. Call Murry at Muzzy and see what he can figure out.
smokinzx14
posted May 09, 2007 06:51 AM
I had to ream the upper hole on the ram... It fit a little to tight and it would bind ....Ream it till it sides easy without binding ...Smokin...
Robmuzzy
posted May 09, 2007 07:38 AM
Brent- Please contact Murray at MUZZYS. 541-385-0706 ext. 108
Brent Davis
posted May 09, 2007 07:48 AM
Thanks guys. Smokin' the upper hole fits perfect and has free movement but I will also call Murray and see what he says. It is just puzzling that the unit has worked great up until the other day.
Thanks Mr. Muzzy, I will call today.
icetee
posted May 09, 2007 10:43 AM
Only a thought, do you think it could be the alinement of the unit from the frame to the shifter, maybe it is off a little, or the angle of it if any......just a thought.
THE VIEW FROM THE REAR NEVER CHANGES,UNLESS YOUR IN THE FRONT!
brent davis
posted May 09, 2007 05:16 PM
Well I got home today and did like Smokin said and just slightly opened the hole up that connects to the frame bolts and slightly bent the shifter just a tad and that seemed to have it working fine either foot shifting or with the regular air-shifter.
Thanks to Murray from Muzzy's as well. He called me back twice today with his thoughts and why's. GREAT customer service from Muzzy's even if I had a problem with the product, they did indeed call me back not once but twice.
Black '06 ZX-14
WARBIRD
posted May 09, 2007 05:33 PM
Quote:
"GREAT customer service from Muzzy's"
Boy, I'd say.................Rob Muzzy himself asking you to contact Murry @ Muzzy's..............
Like he isn't busy or anything.................. It's your VERY nice bike Brent..................EVERYONE digs it...................
I'd Rather Be Roadracing.
BlackMagic14
posted May 09, 2007 07:22 PM
I have heard using an airshifter under normal conditions can bend the shift shafts dont know if that is true but I have heard you should only use air shifter when shifting at higher rpms
smokinzx14
posted May 09, 2007 08:08 PM        Edited By: smokinzx14 on 9 May 2007 22:11
I'm glad you got it fixed Brent .. If the air shifter has ANY bind at all it will not work....I noticed when installing my ram that i had to kind of force it to hook up to the shifter ...By reaming out the upper hole on the ram it would removed that tiny bit of binding...From time to time i add alittle lube to the mounting points ..Muzzys air shifter is a great unit but as any race part it will need a little rubbing here and there ....Smokin..
0.22597217559814 seconds processing time
