BIKELAND > FORUMS > ZX-14.com > Thread: Power Comander ground NEW TOPIC NEW POLL POST REPLY
kawiguy3
posted May 08, 2007 04:09 AM
Where did you ground your PC???
heros will never be forgotton, but legends never die
lietoome
posted May 08, 2007 04:10 AM
behind the bolt for the overflow reservior.
MasterBlaster
posted May 08, 2007 04:23 AM
At the left side ram air tube where it bolts to the plenum. PC is mounted up front under the shield ahead of the cluster.
kawiguy3
posted May 08, 2007 08:00 AM
reason i ask is that my PC seems to be messin up brock said to move the ground so i thought i would see where to put it. also is a bad ground a common thing
posted May 08, 2007 06:36 PM
hook it right to the battery gnd if you are having probs
posted May 08, 2007 06:48 PM
my PC grounded between the water overflow jug and the bike SUCKED after a month or so.
kawiguy3
posted May 09, 2007 04:54 AM
where did you move it to
jim c
posted May 09, 2007 07:01 AM
I grounded mine behind the water overflow also, I also made another wire from the negative side of the battery and ran it behind the water overflow to make sure that I will have a good ground. So far no problems.
Jim
  Ignore this member    Click here to send Jim C an AIM message.
posted May 09, 2007 08:38 AM
my PC grounded between the water overflow jug, no probs so far
WARBIRD
posted May 09, 2007 04:53 PM
Bingo...............
Extend your ground wire ( be sure to make proper terminations ) and ground it at the battery . No more problems.
I have seen so called "expert " driveability technicians using Fluke Digital Volt Ohm Meters, test lights, etc..............totaly stumped because they don't see what they think they should on the test equipment........all due to the fact of a faulty or intermitent ground. ( on the test equipment ) Hard to troubleshoot very low voltage sensors if you don't have a good ground............. ( or accurate test equipment )
I'd Rather Be Roadracing.
0.22313499450684 seconds processing time
