BIKELAND > FORUMS > ZX-14.com > Thread: coby addams straight arm link NEW TOPIC NEW POLL POST REPLY
serius blk
posted April 25, 2007 05:38 AM
Does anyone now how his straight arm link works. I was wondering if it replaces the link thats connected to the bottom of the shock. If this is correct. I wonder if it will work with the standard lowering links. It says on schnitz site that it gives the bike more clearance.
chunter
posted April 25, 2007 05:59 AM
Yes, it is connected to the frame/shock/links.
You will need shorter lowering links in order to get the bike to 3" or less ground clearance. Link holes center to center need to be between 6" and 7" and clearance will vary depending on your shock settings, oil pan/exhaust being used.
Tested with one this past weekend and it lets the suspension progress thru the range as well as the oem piece.
0.23786401748657 seconds processing time
