BIKELAND > FORUMS > ZX-14.com > Thread: zx14 nitrous NEW TOPIC NEW POLL POST REPLY
rayzx14rr
posted April 04, 2007 03:43 PM
zx14 nitrous
cuanto nitro puede aguantar los pistones de fabrica por que yo estoy usando 60hp y quierro ponerle mas tengo 245hp en la goma y 151pies libra
iflyems
posted April 04, 2007 05:01 PM
Je fais pas savons se que votre parler autour de , mais lets tâcher Français. Votre motrice vouloir sauter si vous utilité plus de que 50
Oopss...my bad....it was spanish;
El pistón lata resistir el poder , pero poco more.
ninja14
posted April 04, 2007 08:59 PM
J
loco
salsa1
posted April 05, 2007 04:50 PM
La mejor manera de averiguar cuanto aguanta tus pistones es poniendole 100 caballos addicionales...si el motor no explota le pones unos 50 mas...si aun el motor aguanta ponle unos 40 mas .. siga esta receta hasta que oigas un BOOOOOM!!!!!!
De esta manera sabras sin ninguna duda y podras contarnos cuanto aguanto....y te asseguro que tendras una experiencia fantastica en el processo...
buena suerte!!!
te va a hacer falta...
Salsa1
shawnski
posted April 05, 2007 04:58 PM        Edited By: shawnski on 5 Apr 2007 18:01
say what? no espanol here
posted April 05, 2007 05:47 PM
we are in usa bendayho
NinjaNick
'08 ZX14 (Blue)
posted April 05, 2007 06:01 PM
Actually Canadian website...so I'd reference North America instead...
salsa1
posted April 06, 2007 05:58 AM
Can you spell Diversity??.. ...we are all immigrants on Gods green earth...If God wanted us to remain segregated he would not have sent a man from single race to be everyones eternal Saviour ....a JEW to save us all??...maybe Jesus was white from the USA?? Canadian? Black??
no creo hermano.. I don't believe it...
let the flames roll freely on this .. I laugh along with God at our home made petty ideas of fairness...of course we can control the world .. just take a good look whats happening in it... ...
sticks and stones....
The original question is how much nitrous can the pistons of a ZX-14 take, he is presently using a 60 hp shot and producing 245 hp and 151 ft-lbs of torque. he wants to produce more hp...
Translation free of charge...
have fun..ride while ya can...
Salsa1
shawnski
posted April 06, 2007 06:02 AM
gracias senior salsa :d
posted April 06, 2007 06:25 PM
"The original question is how much nitrous can the pistons of a ZX-14 take, he is presently using a 60 hp shot and producing 245 hp and 151 ft-lbs of torque. he wants to produce more hp..."
muy mucho mariposa
posted April 07, 2007 07:01 PM
lets be respectful, and when in italy do as the saudi arabians and polocks do
thats how all these people do it here, anyway
tonytooth
posted April 07, 2007 08:16 PM        Edited By: tonytooth on 7 Apr 2007 21:22
That's assuming there is a god or even Jesus? Maybe evolution is the cause of diversity and/or segregation?
I am interested in what was being said above. I am in the middle of installing a nitrous kit. I am planning to run a 40 shot but I want to be sure I am safe on the amount of fuel to add with the power commander. Some have told me to raise the fuel bars all the way up on the pc and that would be good. Does this sound correct?
MySpace
  Ignore this member    Click here to visit tonytooth's homepage.
tonytooth
posted April 07, 2007 08:31 PM
rayzx14rr,
how much fuel are you adding to make that much power safely? Thanks
MySpace
salsa1
posted April 08, 2007 10:02 AM
Translation for ray14:
tony tooth pregunta
"rayzx14rr,
how much fuel are you adding to make that much power safely? Thanks"
translation / traducido:
Pregunta: rayzx14rr, cuanta gasolina estas agregando para poder desarollar esa cantidad de caballos sin arriesgar el motor?
o sea .. el ratio de gasolina a aire cual seria? para 60 caballos con nito?
a ver si le puedes ayudar ray...
salsa1
Salsa1
blackbullet76
posted April 08, 2007 10:06 AM
Makes me wish I took spanish back in highschool. I do good to speak english
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
posted April 08, 2007 11:17 AM        Edited By: stevewfl on 8 Apr 2007 12:18
press 1 for english
ok
111111111111111111111111111111111111111111111111
salsa1
posted April 09, 2007 12:34 PM
tonytooth:
got a pm from ray for Tonytooth ; I will translate as best I can:
He informs he uses a wet system using only 1 fogger on the box of the air box looking at the sensor of air temperature. because when the bike was taken to the dyno they realized they could change the air fuel ratio when the nitrous shoots to the sensor; the mixture is at 12:3 and the escape temperature is at 1150f (farenheit?).
Been doing it this way for 8 months and nothing has broken. I have verified compresion along the way and all is intact to date.
This week I will set system for 80 hp and will inform. There is a big race event coming up
and there is a hayabusa turbo that is doing 7.89 at 183 and I want to beat him, I forgot to tell you the jet that indicates the gas table for 60 hp is large and I have to remove it to see what size I used.
take care.
rayzx14rr
If something does not make sense I guess tell me.. I frequent the board .. no problem Tony.
salsa1
Salsa1
tonytooth
posted April 09, 2007 12:38 PM
Thanks much.
MySpace
0.22240495681763 seconds processing time
