BIKELAND > FORUMS > ZX-14.com > Thread: Radar detector wiring NEW TOPIC NEW POLL POST REPLY
Stu64
posted March 25, 2007 01:03 PM
Where do you guys tap into power for your detectors? I would like to use a bar mounted source if possible to make it easiest and less wire.
fastestbusaaround
I eat Fish...
posted March 25, 2007 02:32 PM
Best off using the ign switch harness, located in the lower left portion of the front faring. Just follow the wires leading away from the key.
FYYFF!!!
posted March 26, 2007 09:13 AM
I used a marker lamp lead, always power on when ign is on, and its was really close to the dc recepatcle.
zerMATT
posted March 26, 2007 10:08 AM
+1
Marker lamp was easy to get to for both power and ground. It's little easier than tapping into ignition wiring, and you can simply zip-tie your radar detector power wire along existing wiring bundles to get it up into the faring where the marker lamp is.
0.22165894508362 seconds processing time
