BIKELAND > FORUMS > ZX-14.com > Thread: anybody had cluster apart NEW TOPIC NEW POLL POST REPLY
blue max
posted March 12, 2007 08:29 AM
wanting to know if it comes apart, wanting to wire aux shift lite
best 9.23
ninja14
posted March 12, 2007 08:31 AM
You should wire it to the coil on the #1 cyl. You really don't want to be messing inside the cluster. Also this bike uses a CAN system and you won't get a feed wire......
blue max
posted March 12, 2007 09:55 AM
my plans was to piggyback the existing lite
best 9.23
Xtremespeed
posted March 12, 2007 01:23 PM
The cluster actually comes apart pretty easy if that's what you want to do.
I took mine apart to install my gauge faces. Very simple. Just take out the screws
and pull apart.
When in doubt, Flick it!
posted March 12, 2007 01:54 PM
Thats what I planned to do, runa low powered led light off the existing led.
ninja14
posted March 12, 2007 10:01 PM
I use a Raptor light that is behind the cluster and shines up through the gap.......bright enough to see in the sun :-)
Hey......run the LED up into your helmet - should be able to see that :-)
My point about the CAN was that there isn't really a tach feed as the wires carry mutiple signals to the cluster, but tapping the LED itself should be fine.......pics if you do it......
blue max
posted March 13, 2007 09:51 AM
where did you get your lie from?
best 9.23
lietoome
posted May 05, 2007 06:53 AM
update?
posted May 05, 2007 07:04 AM
I have been working too many hours to get much of anything else done.
lietoome
posted June 04, 2007 06:10 PM
I really need to find out where I can tap into this tach signal. Any help is appreciated.
0.24488997459412 seconds processing time
