BIKELAND > FORUMS > ZX-14.com > Thread: Exhaust Power gains - anything goes NEW TOPIC NEW POLL POST REPLY
sphynx
posted June 04, 2007 04:23 AM
Just for info, was looking at the influence of stock exhausts versus the newer generation pipes and noticed something interesting. A 30 kPa of back pressure results in about 1% power loss, typically high up in the rpm range. Stock pipes such as the stock zx14 pipe together with cat will give you about 300kPa back pressure. Thisw means that by bolting on almos tanything with a straight through perf pipe, you'll gaina theoretical 10% over stock, yet another reason to loose the stock 30lbs of ballast.
"My ambition in life I's to become the person my dog thinks I am" by rabbits losing lucky feet.
posted June 04, 2007 04:25 AM
FYI- there is a plethora of information that has been posted about exhausts if you care to try the search function. also there are directions on top of the thread regarding using the google search tool on this forum
BobC
posted June 04, 2007 05:14 AM
Another reason to bin the standard system is to lose the heat retained by the catalysts. They are so dangerously hot, right at lower leg level, that they should have a heat shield and safety warning by rights. The engine runs cooler on an aftermarket system as well.
posted June 04, 2007 05:18 AM
+1
blackbullet76
posted June 04, 2007 06:11 AM
Hey stevewfl, I'm not saying to not use the search option but every time I use it, it always pulls up threads that have nothing to do with what I typed in. Maybe I'm doing it wrong, who knows.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
ZXLNT
posted June 04, 2007 07:04 AM
The search function on this board leaves much to be desired.
BlackMagic14
posted June 04, 2007 12:17 PM
I think the general consensus is that the Brocks system picks up around 15 HP over stock that is pretty impressive
posted June 04, 2007 04:55 PM        Edited By: bigdtd on 4 Jun 2007 17:56
i cant search worth a shit but steve can, damn
basically the brocks smeg turned second gear into first, and first int whoaaaa!
kinda like the busa post backflip special
make sure you hold on tight
FasterThanStink
posted June 04, 2007 05:42 PM
That's putting it politely. It returns tons of threads with nothing whatsoever to do with the search.
That's what gets you.
0.23238897323608 seconds processing time
