BIKELAND > FORUMS > ZX-14.com > Thread: Dynojet Multi-Function Hub Accessory NEW TOPIC NEW POLL POST REPLY
slow14
posted December 21, 2006 04:28 PM
what would u use it for ,just got mine from the bike shop ?
posted December 21, 2006 05:37 PM
you would use it to connect the ignition module(if available) or a memory module with multiple maps to select from, to start with, also would provide increased connectivity for a laptop computer(more places to plug in)
ZXLNT
posted December 21, 2006 07:16 PM
You can connect the ignition module to adjust timing. It has a gear position harness to sense what gear the bike is in.
It has a relay output that you can probably use to trip a nitrous solenoid. I also believe it can be hooked up to sense boost to retard ignition timing.
If you plug in the map switch you select different maps with a flick of the switch.
I'm not sure if it actually has a USB port on it or not..
BlackMagic14
posted December 21, 2006 10:45 PM
They are available???
slow14
posted December 22, 2006 07:33 AM
yup
they are on back order for awhile thought ,i got mine from matt at drag bike direct ,he got 4 and 3 where sold when i got mine on thursday ,http://dragbikedirect.com/ # 317-694-2137 or call him at 317-889-9990
0.26388096809387 seconds processing time
