BIKELAND > FORUMS > ZX-14.com > Thread: i need help, info NEW TOPIC NEW POLL POST REPLY
bayou boy
posted November 30, 2006 04:54 AM
i need help, info
i got a race in 2 weeks, this guy has a nos busa, he's 260lb's atleast ,but i 'm pretty sure his bike is also a 1397,
what i have is a brock smeg ,tre,straps,44 back sprocket,addin nos this week sometime, my rider is 150lb's , any ides of what kind of dry shot i should get to beat this guy,
this guy is the rudest guy u 'll ever meet, very disrespectful, an talks so much shit , u wanna bus his ass,i 'm in new orleans, la, if someone from the lousinana is on here ,
email me @ tsokennels@yahoo.com
iflyphi
posted November 30, 2006 07:20 AM
iflyphi
posted November 30, 2006 07:23 AM
1 more thing.....Don't race him. If he's that big of a jerk, I'd just let him have the win, and in an obvious way, like redlighting a full second before your supposed to go.
I race for fun. If a guy that im racing is a total piece of shit, and I can't stand him, I won't race him if I don't have to. If I have to......he wins......phuck that, life is too short to get wrapped around the axle about who has the fastest bike.
If HE made the bike, not Suzuki, I'd be impressed. Anybody can bolt on some parts and spray NOS and get it down the track.
Got to SCR, nicer bunch of buys there.
posted November 30, 2006 07:37 AM
Tell him to bring a stock motored with no NOS bike like yours or fuck off...
bayou boy
posted November 30, 2006 11:26 AM
he know the 14 would kill 'em
posted December 01, 2006 06:52 PM
anyone can spend faster
dbeadling
posted December 01, 2006 10:18 PM
turbo time
bayou boy
posted December 07, 2006 07:14 AM
they after market parts bad on this bike
ninjaboy311
posted December 07, 2006 08:33 AM
What times is he posting?? I race at No Problem. Do I know either of you or do you know me?? I race a stretched black ZX-14.
posted December 07, 2006 03:51 PM
you should smoke him
bayou boy
posted December 18, 2006 09:43 PM
whats ur name, isac
BlackMagic14
posted December 19, 2006 01:18 AM
a typical 1397 busa is prolly about 210 HP if he has a forty shot and you have a forty shot that would put him at 250 RWHP and you around 185+40=225... i.e bike wet weigh 543 a piece i think so 543 plus his 260 puts him at 803 803/250=3.0884 pounds per hp your bike 543 plus 150=693 693/225=3.08 exactly pounds per HP assuming Identical rider skill your bike should win... I give you a little added edge cause I assume since you did not mention it you are both stock length so I assume again that you will not be spraying right out of the hole and with the flies out on the laun ch you are going to have more torque even then a BIG busa, so with a lighter rider you should hole shot him pretty good and I have seen enough 14 hold off BIG busas around here to think that you should be able to hold him off... In my opinion you should try to negotiate no squeeze I think then definately you take the win assuming of course your rider can ride... lets look at the numbers without the squeeze and see how they look his 803/210=3.8238 lbs per HP your 693/185=3.7459 so you can see that without the nitrous you have a BIG advantage... also take into account that you will only have about a week to "dial" in your nitrous unless you are getting a full custom nitrous map made... here is a little tidbit I normally dont share with folks but I used to live in meteraie so I will give you a freebie.... cutting the back section out of the seat is a perfect way to hide a 1 lb nitrous bottle then you just pop the seat cowl on and migically "no nitrous" and keep in mind because the 14 doesnt have a "trunk" like the busa no one EVER expects a bottle to hidden there I have okie doked many a busas with that one can only get em once though but hey that is why in street racing I always bet the BIG money on the first race... LMAO just fyi let me know if you are looking to buy a NOS kit I am selling my complete kit for 300 with the bottle. for 400 I will include the cut out seat so you dont have to ruin yours, I am wanting to get a wet kit for mine but either way let us know what happens GOOD LUCK thanks for representing NOLA
posted December 19, 2006 08:43 AM
tell him to get a stock motored busa without the dope
Or his bike with the bottle disconnected and you get to use the dope...
That would make it close
the 1397 is more than just 45 cc larger...
Its higher compression, likely ported and cams.... about 215 HP
at least 25 RWHP more than a piped zx14.
Don't burn a piston trying to prove a point either.
Make sure your set up right.
He's a sandbagger.
suicycle
posted December 19, 2006 12:38 PM
We have two big busas around here both over 1400 ccs (I think 1426?) both built by 2 different builders. Both have ported heads, cams, falicon super cranks, falicon knife edge rods, as well as the big bore kits. Both are stock length and height. Both bikes have been dynod ( two different dynos) and both were right around 200hp. One was 202 at the wheel the other was 196 at the wheel. The 196 hp one does have lower compression (12-1) while the 202 hp one has 13.5-1 compression. The 196 hp bike and mine are real close to even in the 1/4 mile and he is a lighter rider (im 260, and he is 170) but his bike is harder to launch due to the extra torque, he has to take is easier in first gear than me and so he has to spend the rest of the 1/4 running me back down....he will come around me eventually but its after the quarter mile. The other bike I havent run againsr but he is more of a bench racer than actual racer. So I havent been able to get him to run yet. Oh, by the way my bike dynos out at 188hp on the same dyno as the 196 hp busa. I have brocks Gen III, power commander and TRE, and I am also stock length. None of the bikes are lowered. And the two of us that have raced have quite a bit of drag racing experience. Either way as long as your guy can ride you shouldnt have a problem with the busa.
bayou boy
posted December 20, 2006 10:34 AM
cool, it was put off, right now ,i 'n in the process of of geting that 1417 cc piston kit,an i know i 'll get him, this guy runs his nos through his throttle, so he comes off real hard, but he's a huge guy
bayou boy
posted December 20, 2006 10:36 AM
deff, i 'll buy it, tsokennels@yahoo.com , email me
1badzx12r
posted December 20, 2006 10:46 AM        Edited By: 1badzx12r on 20 Dec 2006 10:50
man, my boys zx-14 with just a full brock smeg exh, killed this 05 busa, these busa guys are stubborn, they took even,bout 20yards, 14 pull away, bout half through 1/4 mile , it was over, like 10-13 bikes, 3 stright times, this busa has a ti -force, smartswitch, pc, every thing, got destroyed,
then he wants to race me, my 14 has nos, muzzy set up, airshitfter,brock smeg,pc3, tre switch, 44 sprocket, ceramic wheel bearings, strap in front, extented 5-6in, i didn't even spray him, had to about for real alot of bkes i put on him, i was already dam near stop when he cross the line ,
he came up with a million excuses, at the end , u know what he said, wait till 1500 comes out., i said well wait. but for now, u got ur ass whip............................................................................................................................................................................................................................ you posted this... now you scared... be a man take ur medicine...you made ur bed now lie in it....
bayou boy
posted December 20, 2006 07:20 PM
no i didn't call it off, dude never showed up
posted December 21, 2006 12:04 AM
after all this drama lmao
0.23038506507874 seconds processing time
