BIKELAND > FORUMS > ZX-14.com > Thread: oil light keeps coming on. need help NEW TOPIC NEW POLL POST REPLY
MACSOLO
posted November 03, 2006 01:19 PM        Edited By: MACSOLO on 3 Nov 2006 13:21
hey guys, i got a oil pressure problem. i burst my oil pan a few weeks back. got it fixed then raced a few times and now my oil light flickers on and off . i alreAdy vented the system by cracking open the filter to expel the air but it still did not work? has anyone else had this problem if what was your fix.
aliveagain
posted November 03, 2006 03:15 PM
clean the screen?
posted November 03, 2006 03:18 PM
Check the pickup tube?
posted November 03, 2006 03:30 PM
Put oil back in the bike?
posted November 03, 2006 04:13 PM        Edited By: smokinZX14 on 3 Nov 2006 16:14
Forget to get the oil sending wire tight after reinstalling the pan ?
wrongway
posted November 03, 2006 05:18 PM
is that at an idle , or when the rpms are up ? if the light comes on during higher rpms , the sump pickup maybe too close to the pan. the pan can get pulled up and starve the pump.
I am not sure if there is anything there to maintain the proper distance to the bottom of the pan.
if it is low at an idle, it maybe bearing wear from the loss of oil when the pan was broke.
Roy
posted November 03, 2006 09:11 PM
loose sending unit wire/
bad sending unit?
pickup plugged
screen plugged
schrapnel in the oil passages
could be many things
nightmare
ACP Racing
posted November 04, 2006 06:42 AM
hey, maybe even the pump. but I'd go with trash in the screen first.
2006 ZX14 Ninja "SWINE FLU"
60ft 1.23
8th Mile 5.16
ACP Racing
posted November 05, 2006 05:25 AM
Check the oil pressure release valve when you drop the pan...Could be damaged?
psycho1122
posted November 05, 2006 08:01 AM
I would inspect the Oil pump rotor (replace if nicked up) and install a new oil filter in conjunction with a pan drop and screen inspection.
0.54498410224915 seconds processing time
