BIKELAND > FORUMS > ZX-14.com > Thread: Can the 14s alternator handle 15 amps? NEW TOPIC NEW POLL POST REPLY
nabrxx
posted November 04, 2006 04:43 PM
I just sprung for heated gloves and a heated vest..do I have to worry about the battery not charging?
What we don't understand, we can
make mean anything... src="http://www.bikeland.org/board/i
mages/smilies/smile.gif" border=0>
pdonnell
posted November 04, 2006 09:27 PM
That would equate out to be about 1650 watts. Most bikes have put out juice for 400 to 800 watts for a heavy tourer. Gloves and heated vest no problem on the ZX. Your not taxing the alternator adversely while running. Your vest and gloves have a watt rating. But should be no problemo.
zx12mark
posted November 04, 2006 09:56 PM
1650 watts is too much extra load on the alternator.sportbike electrical systems do not have that kind of head room.your gonna fuck some components up.you'll be asking your bike to operate at low voltage even while the alternator is maxed out.
you have been warned!
RunningFree
posted November 04, 2006 10:02 PM        Edited By: RunningFree on 4 Nov 2006 22:04
Huh???
Your power requirements are:
P = VI = 12.5Volts at nominal load (could be a different voltage, check your vest rating) * 15Amps = 187.5Watts, not 1650W...
The alternator's rated output is 35 Amps @ 14V = 490W so you shouldn't have any problems, unless nominal load (meaning power necessary to supply lights, ignition, injection, fan, fuel pump, ecu, sensors, sec. butterflies, etc.) is higher than 20 Amps.
I haven't measured nominal Amps, yet...
2006 ZX14 Black
2005 SV1000S Red
2002 VFR800A Red(sold)
The best part of repentance is the sinning
Bently
2012 14r In Blue and no Mods!
posted November 05, 2006 07:24 AM
I've used my heated Gerbins jacket and gloves on my sv650, fjr 1300, zx10r, ninja 250, and now my zx14 with no problems at all. use it all you want and be happy and warm! you will not fu_k anything up.
posted November 05, 2006 07:52 AM
Yah, same gear here, no probs!
nabrxx
posted November 05, 2006 08:14 AM
Thanks guys...Ill keep you posted if any probs.
0.2759690284729 seconds processing time
