BIKELAND > FORUMS > ZX-14.com > Thread: Schnitz racing efir install help needed!! NEW TOPIC NEW POLL POST REPLY
mrsantafe
posted October 26, 2006 03:30 PM
"The efir module is designed to plug into the existing Crankshaft Trigger wiring harness. The connector is located under the right side of the throttle body assembly."
1. Do i have to remove both side fairings to get to this?
2. Next it says to "Connect red wire to +12v switched source(comes on with the ignition Switch)" black wire to the negative battery terminal.
3. yellow wire to a nos controller or +12 v activation source.
I'm only using the timing advancer feature and i'm not sure if i have to hook up the yellow wire at all.
Whats a good +12 v switched source to connect to the red wire?
I appologize for seeming a bit ignorant when it comes to wiring. thanks in advance!
ps: anyone have pics of this install??
2006 ZX14 gone
2004 zx10r (her race bike)
2002 ZX12 (still kicking a--)
2007 gsxr 1k (race bike)
posted October 26, 2006 08:14 PM
pm zx bob...
I think he runs one.
buddy
posted October 26, 2006 08:55 PM        Edited By: buddy on 26 Oct 2006 22:04
I was going to try to help, but noticed I was in the 14 site. Mine is mounted in a 12R.
The box has to be activated, tho, to start it doing it's job, so the yellow wire will have to be activated by a button or wot switch or such.
Kawracer
posted October 27, 2006 06:13 AM        Edited By: Kawracer on 27 Oct 2006 07:16
#1.You only need to take off the right side to get to the connector
I used the power leads that went to the license plate light ,( Assuming that you have taken off the rear fender) see the white connector in the pic.
2004 & 2005 PMRA Street E.T. Champion
mrsantafe
posted October 27, 2006 01:42 PM
Thanks, a pictures worth a thousand words. I did indeed remove the rear fender.
0.30601906776428 seconds processing time
