BIKELAND > FORUMS > ZX-14.com > Thread: Front end rattling noise NEW TOPIC NEW POLL POST REPLY
chris3232
posted August 13, 2006 03:23 PM
I hear a rattling noise from the area of my windshild and spedometer pretty much at all speeds. I took it in for a 600 mile svc and mentioned the noise to the dealer. They tightened down the screws on the windshield but that didn't help. Anyone familiar with this.
dbeadling
posted August 13, 2006 03:33 PM
maybe loose tip over switch.....did you do the recall?
FasterThanStink
posted August 13, 2006 04:00 PM
Yup. Probably a loose tip over switch. Have it checked. It is located under the forward part of the windscreen. There is a recall for certain VIN numbers for this. Your dealers should check.
That's what gets you.
BAboyonaBAtoy
posted August 13, 2006 05:04 PM
the tip over switch itself is whats ratlling
zerMATT
posted August 13, 2006 05:37 PM
I can hear the "innerds" of my tipover switch rattling quite a bit... mostly while slowing down for a stop. No biggie... I know it's attached well because I torqued it myself, but the rattling gets my attention sometimes.
posted August 13, 2006 05:48 PM
Does it sound like tiny balls ratting, zerMATT?
zerMATT
posted August 13, 2006 05:50 PM
tink-a-tink-a-tink.... clicky-clicky-clicky...
It's a lot like the noise that the front brakelight switch makes if you tap your brake lever quickly.
3Boysand3Bikes
posted August 13, 2006 07:55 PM
CHRIS3232, I did the work for you and went through some old threads and found the time and date of an entire thread discussing your problem.... , for more info check on page 15 or 16 for a heading talking about a recall....
The one I added below shows the date and time of the thread. I did as suggested... I taped the tip over switch up real tight.. and I don't hear it at all. Also, be careful not to tigten the screws too tight on the plastic because that also can cause a buzzing...
Have you hugged your 14 today?
posted May 23, 2006 08:35 PM
Just checked mine..................1 bolt slightly loose. The whole thing is rubber mounted, so it moves around a bit. Those that have heard rattles in your upper dash, this is probably the culprit.
2006 ZX14(In my garage!)
2002 ZRX 1200R(sold)
2004 Suzuki SV 650
bugsey
posted August 13, 2006 08:12 PM
WHATS A TIPOVER SWITCH
zerMATT
posted August 14, 2006 04:35 AM
It kills the engine in the event that you exceed the maximum safe lean angle. Translated, that means that it kills the engine if you CRASH!
vtxtc
posted August 14, 2006 05:27 AM
tipover switch
Rattle is caused from internal metal pendulum rattling aginst inside of tipover switch-located directly under windscreen-take windshield off and hold switch tight-flick with finger and you will here the noise-rapped mine with several layers of dynamat that can be gotten at most stereo shops,rattle is 98%gone.
fastestbusaaround
I eat Fish...
posted August 14, 2006 07:01 AM
Most bike since late 90's have the Tipover switch, or Lean sensor, or down sensor...goes by many names...
FYYFF!!!
bugsey
posted August 14, 2006 09:01 AM
hey Matt...I know...I wus just messin with fish.....hadn't messed wif em in a long time.
0.24379992485046 seconds processing time
