BIKELAND > FORUMS > ZX-14.com > Thread: drilling exhaust NEW TOPIC NEW POLL POST REPLY
rcookr
posted August 02, 2006 12:58 PM
drilling exhaust
Just wanting to know?. I had a 2001 gsxr1000 and a cheap mop was to drill the muffler. Has anyone tried this for some more power and exhaust note.
htosado
posted August 02, 2006 01:06 PM
Good question!!!
posted August 02, 2006 01:08 PM
I'd imagine alot of work, to remove the baffles and cats too, without destryoing the canisters
rcookr
posted August 02, 2006 01:13 PM
No we would just drill it with a 12inch drill bit. Look inside the muffler you can see plate, just a couple of hole there and it should reduce some back pressure and maybe make the exhaust a little louder work on the gsxrs
rcookr
thats a 12 inch long bit and 1/2 inch dia
scificanada
posted August 02, 2006 01:14 PM
There was a thread a few days back that showed a cut out of the stock cans.
I think the most restrictive part are the cats as dubious alluded to
Be a predator, not prey.
2006 Blue(the fastest colour) ZX14, Brock Ti Gen 3, Secondary Butterflies out, PCIII with Brock Map, Muzzy Frame Sliders.
htosado
If you do it, let me know.
rcookr
posted August 02, 2006 01:21 PM
I now the cats on the 2005 yzfr1 dont hurt power at all its in the mufflers on that bike.
scificanada
posted August 02, 2006 01:32 PM
Hmmmmmmm, Curious...
But I love my Brock..
The Stock cans are so damn heavy
I was amazed at the increased handling once they were gone.
frEEk
posted August 02, 2006 02:47 PM
exactly. imho not worth drilling the cans cause of the weight. spend a little cash (area p's slipons are quite reasonable) and save a gob of weight as well.
posted August 03, 2006 06:36 AM
Spoken by the Zen Master of 'Oh, I don't need to buy a tire. Yah, the cords are showing, but I can make it to Laguna!'
frEEk
posted August 03, 2006 09:56 AM
no, i can make it _back_.
rcookr
posted August 08, 2006 08:28 AM        Edited By: rcookr on 8 Aug 2006 10:06
does any one have cut away pics from the dealer shows cant find any and want to try this mod thanks
fastestbusaaround
I eat Fish...
posted August 08, 2006 08:36 AM
Huh? Once more in English please...
FYYFF!!!
iflyphi
posted August 08, 2006 10:02 AM
He meant this;
zerMATT
posted August 08, 2006 10:26 AM
or this:
Tool Man
posted August 08, 2006 11:26 AM
Take them off to do it. I f there are any chips left in pipe could be bad news on a hard decel. Possible to suck backwards into cylinder??
The banks are failing..
The banks are failing...
Invest in Ammo
rcookr
posted August 08, 2006 12:33 PM
I dont think there is any chance of metal shavings getting sucked back to the engine just start up the bike and a few wacks and everthing will be blown out but I might take them off
rcookr
posted August 08, 2006 03:19 PM
Ok job is done 3 1/4holes in each muffler sounds nice more of a louder deep tone
MasterBlaster
posted August 08, 2006 04:31 PM
Want to know cheap and quick? Saw off the muffs with a band saw, that way you have the stock mid pipes. Put on a set of junk slipons you have laying around the shop. You have lost the weight and all it cost is a little time.....TB
rcookr
posted August 08, 2006 04:39 PM
kinda like the junk ones on your bike
ny28av
posted August 08, 2006 06:44 PM
i did it............ sorry i dont have any pics, but.... im a welder. i cut the left pipe off and welded a cap on the left flange and tightend it back on, then i cut the end of the canister (tacked on) and used a plasma cutter to cut the baffle plate out, then tacke it back on. then i cut the upper piece off and removed the "cat", and the mesh piece behind it.
i was getting some popping on decel, with a little bit of back fire. so i plan to plug the hose, in the future for full system application. so far so good. it sounds nice, not so abnoxiously loud, w/ nice power. no map or TRE yet. Please reply w/ pros or cons.
ny28av
posted August 08, 2006 06:45 PM
sorry, i forgot to add....... all i have now is a single rightside exhaust..
lietoome
posted August 08, 2006 09:17 PM
ny28nav,
what do you think a shop would charge a non-welder? Ballpark?
rcookr
posted August 09, 2006 07:52 AM
wentto 4 holes 1/4 in each muffler
0.21992921829224 seconds processing time
