BIKELAND > FORUMS > ZX-14.com > Thread: How much HP is your chain robbing? NEW TOPIC NEW POLL POST REPLY
posted July 31, 2006 07:42 PM        Edited By: dubious on 31 Jul 2006 20:47
Well, I tried chain wax on it, as it does not fling off, and dries so it will not attract dirt.
Used it on MX chains for some time now.
I noticed my chain was getting less flexible. The wax and dirt were gumming up the action.
I had one of these lying around but have never used it:
Its called a chain scrubber made by "MOOSE" off road accessories.
it did wonders. It comes with a cleaning solution which i beleive to be keroseen.
mine was the 520 chain model for dirt bikes, but it worked on the 530 chain on the 14 because chain pitch is the same, just the width of the links are different.
It really free'd up the binding from crud and crap.
It also has a lube port to hook up the lube tube,, and keeps the chain lube where it belongs... on your chain when applying it.
I highly recomend it!
BTW, I would say it freed up 1/2 HP LOL
Power ... we need more power captain !
Now my chain follows the sproket better instead of bouncing, and making noise off the slider.
BTW what are you using for chain lube?
I'm considering just using WD40, but have heard mixed reviews, as it swells and cracks the o-rings supposedly.
fastestbusaaround
I eat Fish...
posted July 31, 2006 08:01 PM
WD40 corrodes rubber...PJ Blue got the best write up, but flings off bad so I still use chain wax..on the inside of the chain only and then I wipe off the excess on the outside and top. Kerosene is perfect for getting the dirt off and I do a hand clean (spray bottle) every 6-7K or so with it...takes only 15 minutes and the chain and sprocket look factory fresh. My chains last well over 30k, usually...
FYYFF!!!
posted July 31, 2006 08:05 PM        Edited By: dubious on 31 Jul 2006 21:08
you need to try one of these, no mess on the floor, clean hands, 2 minute job, no overspray from lubing!
There is a sproket inside and brushes, that scrub the rollers, and both sides of the plates.
It really is a cool peice!
My $300 chain was like new.
I used to do it by hand, but hand cleaning will never do as good a job
I'm pretty anal, and only give props when i really like something!
$30!
I will own one forever ...
fastestbusaaround
I eat Fish...
posted July 31, 2006 08:10 PM
Lookin online for it now!
FYYFF!!!
posted July 31, 2006 08:16 PM
I think Parts Unlimited/ Canada carries them.
fastestbusaaround
I eat Fish...
posted July 31, 2006 08:17 PM
'nuther chain clean /lube debate here....
http://www.webbikeworld.com/r3/motorcycle-chain-cleaner/
FYYFF!!!
posted July 31, 2006 08:32 PM        Edited By: dubious on 31 Jul 2006 22:16
OK , I gave that a quick peruse.
The moose has a lid that slides off the bottom case, do not pry upward, slide it off.
Put the bike on cenetr stand , or rear stand for best results, to keep the case level, and fluid in the box.
I dumped the solution in ther 1/4 full like moose suggests, put the bottom case under the bottom side of swingarm, slid the cover on, rotated the wheel by hand in reverse direction, till the box touched the frame, then continued to run the chain backwards, for about 10 quick complete rotations.
Let the cleaner sit for a 2 minutes while finnishing my beer, then another 5 quick rotations.
Remover the box, and dumped the contents into my used oil container, wiped excess cleaner off the chain, wiped out the box quickly and stored away for next time.
probably not necessary to let it sit, but I'm anal.
Voila perfectly clean chain, looks new and seems to have less friction than new.
That other contraption looked awefully awkward.
frEEk
posted July 31, 2006 10:05 PM        Edited By: frEEk on 31 Jul 2006 23:05
u can lose alot more than 1/2 a HP with a bad chain. i seem to remember k bryant talking 3 to 5HP possible.
i like the idea of that Moose kit. may have to pick that up.
Lilrock04blue12
posted August 01, 2006 05:02 AM
here you go guys
http://www.motorcycle-superstore.com/item.aspx?style=5220&department=646&division=6&WT.MC_ID=80003
Tool Man
posted August 01, 2006 08:26 AM
you need to try 2 minute job
I used to do it by hand, but hand , will never do as good a job
$30!
HEhehe You said it ....sort of
The banks are failing..
The banks are failing...
Invest in Ammo
salsa1
posted August 01, 2006 09:11 AM
Add says:
With internal brushing sprocket removed, chain lube can be applied easily and evenly through a built in applicator ..
what sprocket needs removal?
Can clean while spinning rear tire means can clean chain whith chain and both sprockets in place or not?
If no removal of anything looks like a very good buy..
Salsa1
fastestbusaaround
I eat Fish...
posted August 01, 2006 10:01 AM
No sprockets need removal...not for cleaning, not even without the moose box...
FYYFF!!!
BlackMagic14
posted August 01, 2006 11:07 AM
Where can I get the moose one and how often would you say you need to clean
fastestbusaaround
I eat Fish...
posted August 01, 2006 11:33 AM
Look up in this thread to buy...the URL is a few posts up...I clean every 5K or so, but also wipe down after each lube...Dubious says that the Moose box works very fast...I do it by hand to clean the chain and sprocket...takes me only 15 minutes to get it lickety clean. Might buy the box and clean more often though
When you run out of the "sludge away" that came with the box, just use Kerosene...works fast...some say WD40, jury is still out on that one.
FYYFF!!!
Stalwart
posted August 01, 2006 11:59 AM
I like Diesel for cleaning . . .
Stuart
Ridin' the Trump train.
zerMATT
posted August 01, 2006 12:31 PM
Add says:
I think they are talking about removing a sprocket from inside of the Moose cleaner gadget - not a sprocket on your motorcycle.
fastestbusaaround
I eat Fish...
posted August 01, 2006 01:15 PM
LOL...
FYYFF!!!
salsa1
posted August 01, 2006 03:25 PM        Edited By: salsa1 on 1 Aug 2006 16:32
Will it work for a 525 chain.. like on my ZX-10R?
It is listed for a 520 chain...
Salsa1
posted August 01, 2006 07:04 PM
yes, they make them for 520, 525, and 530 chain.
I happened to already own one for my dirtbikes 520 chain, and it works on the 530 as well!
blueford
posted August 01, 2006 07:32 PM
Shit, how about humid air?
blitzkrieg
Road kill = Free lunch.
posted August 01, 2006 08:10 PM
Don't breath into your ram air BF and it won't be a problem.
P.S. - Stay over in the Smackhouse. You are lost in the tech sections. LOL
posted August 02, 2006 05:01 AM
I have that same cleaning tool. Very handy!
fastestbusaaround
I eat Fish...
posted August 02, 2006 07:53 AM
-- agreed...had said the same thing, but the POS just won't listen...
FYYFF!!!
0.24153614044189 seconds processing time
