BIKELAND > FORUMS > ZX-14.com > Thread: TRE?? Worth $70?? NEW TOPIC NEW POLL POST REPLY
jnybbad
posted June 29, 2006 08:07 PM
TRE?? Worth $70??
I read bout this , www.ivansperformanceproducts.com/tre.htm, on a different site. Who has used it on the 14 and what are your thoughts.
TJ
posted June 29, 2006 08:27 PM
Do a search on this forum. You will find plenty of threads discussing the TRE..
jnybbad
posted June 29, 2006 08:58 PM
TRE
I did and the search turned up nothing. Do you have any links?
posted June 29, 2006 09:04 PM
http://www.bikeland.org/board/viewthread.php?FID=27&TID=24115
BobC
posted June 29, 2006 11:26 PM        Edited By: BobC on 30 Jun 2006 01:49
The downside of the TRE, based on my experience of using one on my Suzuki, was that it disables the gear position indicator, reads 5 all the time. It just seems to be a resistor in a box with a couple of connectors and you could do that yourself for next to nothing. Is it worth the money ? I don't think so.
Thought I'd add this, so it doesn't sound like a rant. To be fair to Ivan it's an excellent and simple idea, well marketed. The question, however, was do I think it's worth $70.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
cls
posted June 30, 2006 03:15 AM
Very briefly: Yes, it helps and it's worth it, I think. If you are so inclined, maybe you can rig your own. Not me, unfortunately. It does what it's supposed to do. You'll notice a difference.
posted June 30, 2006 05:40 AM
CLS - what bike do you have it on?
swiftkart
posted June 30, 2006 06:09 AM
I have one on my 14 and it was a noticeable increase, I can pull on my friends stock 14 now, we use to run side by side...you lose the gear indicator and lauch light, but the shift light still works.
cls
posted June 30, 2006 06:27 AM
I currently have it on my 14. Third day w/it on there. I also had it on my 'Busa. It makes a nice difference. Nothing huge.
0.23455595970154 seconds processing time
