BIKELAND > FORUMS > ZX-14.com > Thread: DYNO RESULTS !!! AND ALOT MORE!!!!! NEW TOPIC NEW POLL POST REPLY
zx1kr
posted June 10, 2006 03:51 PM        Edited By: zx1kr on 10 Jun 2006 16:57
1st let my start by asking someone that has posted pics in the past to allow mme to E-mail the actual results. I have tried to post pics in the past with no luck!
The results are a bone stock ZX14 with 10/40w Non Synthetic oil. 852 miles on ODO.
Next I give you what I got!
Speedohealer set to 10% correction checked calibration steady up to 160mph give or take 1mph. Got alittle busy past that! If you set the SH @ 10% you are dead balls on w/stock gearing!
4th Gear run set at same STD w/3 smoothing that Brock Posted his Dyno info with
166.20 HP @ 9800rpm 104.04 LB/FT TQ @ 7900rpm
6th Gear Run for max speed:
Broke 200mph on Dyno! The Dyno sheets I will post will show approx. 196mph due to me ending the run before the dyno did its auto shut down @ 200mph.
Also the HP# for that run was168.05 & TQ # was 103.33
The speedoHealer seems to have eliminated the restriction. What I did notice is my Gear Indicator tells me I'm in 5th not 6th when I get into the upper statosphere. I thought it was me in the wrong gear but I tried it a couple a more times & it happened again! I will check that out alittle more before passing judgement.
More info!
4th Gear roll-on HP# 37.03 TQ# 57.14
6th Gear roll-on HP# 47.76 TQ# 73.63
The ECM is opening the secondaries in 5th & 6th. BIG difference in those #'s
Look at the A/F when posted. When this thing is tuned I'm gonna get some FAT #'s!!!!!!!
Sorry for delay on maps. I have to scan them into my pc at home & I will e-mail them to 1st E-mail address I get. Just give me a few minutes.
zerMATT
posted June 10, 2006 03:57 PM
PM with email addy sent.
posted June 10, 2006 04:00 PM        Edited By: dubious on 10 Jun 2006 17:04
click on email button below this post.
to email me
I will upload to imagestation for you and post.
If you wish heres link to imagestation you canopen your own free account.
http://www.imagestation.com/mypictures/download.html
when posting here use [ ] brackets
put img inside brakets at beginning and /img inside brackets at end of file location.
same thing but url and /url inside brackets for links
zx1kr
posted June 10, 2006 04:01 PM
Give me a few seconds I haven't scanned yet just got back from shop. 1st thing I did was post this.
zx1kr
posted June 10, 2006 05:00 PM
zermatt you should have a few of the maps now. Sorry for the delay. Had to download drivers for the scanner. (New PC)
havabusa12r
posted June 10, 2006 05:41 PM        Edited By: havabusa12r on 10 Jun 2006 18:46
zx1kr's dyno chart:
see below.............
(68 Yam 175 2-stroke)
(99 Copper Busa) (99 Duc 900 SS full fairing) (00 MV Agusta F4S) (02 Aprilia RSV Mille) (02 ZX 12r CTB) (03 KTM 950 Adv)
(04 Yam R1) (05 LE Busa) (07 ZX 14)
havabusa12r
posted June 10, 2006 05:43 PM
oops:
havabusa12r
posted June 10, 2006 05:46 PM
size medium:
zx1kr
posted June 10, 2006 05:56 PM
havabusa did you get the 2nd one showing the top speed on bottom? It was a single run.
zx1kr
posted June 10, 2006 05:59 PM
Oh yea, thanks for postin them for me!
havabusa12r
posted June 10, 2006 06:08 PM        Edited By: havabusa12r on 10 Jun 2006 19:11
Sorry, I'll post it up
(they had the same name, I thought they were the same)
My screw up. Hold on
havabusa12r
posted June 10, 2006 06:10 PM
zx1kr
posted June 10, 2006 06:19 PM
Sorry so light. I had to scan photcopies, had a problem w/ Internet connection from shop.
But, if you look in the lower right corner you will see the 194.6 MPH . It pulled to 200mph no more restriction.
zx1kr
posted June 10, 2006 06:39 PM
Na, my screw up I'm alittle slow with the pic posting thing.
I e-mailed it to someone else the charts too but you got it done.
serius blk
posted June 10, 2006 07:03 PM
zx1kr you are tell us that the speedohealer took off the restriction. The bike pulled to 200mph. You dont have a tre on it either. If this is legit tell me what kind you got.
zerMATT
posted June 10, 2006 07:28 PM
Sorry zx1kr, I got roped into mowing the lawn and just finished up. Glad to see hayabusa12r got them posted up for you
serius blk
posted June 10, 2006 07:30 PM
And yes on speedohealer site it does say it can remove the top speed limiter.
posted June 10, 2006 07:31 PM
Nice to know .... Thanks for the info.....
zx1kr
posted June 10, 2006 07:46 PM
No TRE in bike. Installed speedohealer, corrected @ 10% dead on! The bike ran right into the 200mph auto shut on Dyno. The 200 mph was confirmed on dyno speedo not the zx14's speedo. Although, the zx14's speedo was BURIED!
zx1kr
posted June 10, 2006 07:48 PM
No problem zerMATT
serius blk
posted June 10, 2006 07:51 PM
you didnt have the secondary butterflies out either. I definitly have to get one for my bike..
serius blk
posted June 10, 2006 07:53 PM
Hey zx1kr do you remember where the rpm when it hit 200 area.
zx1kr
posted June 10, 2006 08:05 PM
I was past 11k, I looked down & it looked about 11.2 or 11.3K. No butterflies out but, if you look @ the A/F on the 2 runs overlapped the 4th gr. run is on the rich side down low & the 6th gr. run leans out at the same spot (ecm opened secondaries?) I would think that just removing the secondaries would not be any worse than what the 6th gr. run looks like as far as A/F is concerned. I myself will just wait for the correct PC3usb & install a good exhaust , at that point I will remove those little buggers. I will be sure to get that info up too.
supra5677
posted June 10, 2006 08:34 PM
Congrats dude My 12r spun the dyno drum passed 200mph and hit the dyno brake still pulling. But that was with an extended rev limit ecu and Muzzys Bonneville Box. Your bike did it stock!!
posted June 10, 2006 09:03 PM
zx1kr you are the man.
Will be ordering a speedo healer on Monday!
0.25255703926086 seconds processing time
