BIKELAND > FORUMS > ZX-14.com > Thread: Rear Sprocket NEW TOPIC NEW POLL POST REPLY
EASY
posted June 05, 2006 12:00 PM
Rear Sprocket
Just for everyone's info---the rear sprocket on the 14 is NOT the same as on the zx-12. Just found out by orderding a 44 for a zx-12 and the bolt holes are not the same.
  Ignore this member    Click here to send EASY an AIM message.
Mano 2
posted June 05, 2006 12:31 PM
Send Sprocket Specialist will sell you a blank if you can give them an ID.
Then you only have to drill your own bolt holes.
Or send them your sprocket and they will make your sprocket to your specs in about 10 days. Sooner if they already have 14 sprockets available.
droid
posted June 05, 2006 02:09 PM
Drill your bolt holes!
posted June 05, 2006 02:55 PM
good luck getting them all perfectly centered..... let them cut the holes!
0.26767802238464 seconds processing time
