BIKELAND > FORUMS > ZX-14.com > Thread: Flasher Relay NEW TOPIC NEW POLL POST REPLY
zxlnt
posted June 01, 2006 10:01 PM
Flasher Relay
Electronic perhaps.?? I want to switch over to LED'S in the turn signal lamps so I was out hunting for the flasher relay. I believe its on the left side in the rear tail section. I turned the blinkers on and listened for a click. Couldn't hear a damn thing. I'm hoping its electronic and not load dependent like a regular bi-metal flasher...
So anyone else replace the regular blinker bulbs with LEDS yet?
fastestbusaaround
I eat Fish...
posted June 02, 2006 01:44 AM
If you have a problem, do what I recommended over on the 10R forum...we did an R6 this week and it was done that way with perfect results.
FYYFF!!!
zxlnt
posted June 02, 2006 02:46 AM
Load resistors? Yeah, I've had a homemade tailight integrator and LED tailights on my 12R for 5 or 6 years now with load resistors.. I would rather get away from that and use an electronic flasher. The resistors work fine but lots of wasted electricity turned into heat...
fastestbusaaround
I eat Fish...
posted June 02, 2006 02:50 AM
Ya, but it has no ill effect on the circuit, costs only pennies, does the job perfectly and if the flashers are not electronic, you don't have much of a choice anyway The so called "load equalizer" circuits you can buy are exactly that for much more money in a plastic case anyway. Anyway, there isn't enough heat on the bike...
FYYFF!!!
zxlnt
posted June 02, 2006 03:03 AM
If can use an electronic relay thats basically plug in instead of cutting/splicing or crimping some damn resistors into the circuit I would rather do that. Now to find some bright 1156 Yellow LED'S that will fit in the blinker housings..
fastestbusaaround
I eat Fish...
posted June 02, 2006 03:14 AM
customdynamics.com
FYYFF!!!
zxlnt
posted June 02, 2006 03:21 AM
www.ledtronics.com
0.26470994949341 seconds processing time
