BIKELAND > FORUMS > ZX-14.com > Thread: Supercharger NEW TOPIC NEW POLL POST REPLY
712
posted May 30, 2006 04:33 PM
Supercharger
http://www.calisuperbikes.com/
Check this out I am first guinea pig maybe? waiting for call from these guys.
HOLD ON TO YOUR ASS THE FAST BITCHIN IN BLACK FREIGHT TRAIN MIGHT BE COMING FOR YOU...
CaliSuperbikes
Posted: Mon May 29, 2006 12:38 pm Post subject: Supercharged ZX14 - need a guinea pig!
Hey gents, just found your site - some of you have heard of me, some of you haven't. I run California Superbikes, and we design and build supercharger kits for the fastest of the fast. As the ZX-14 is the new dominant speed demon, we want to supercharge it! You guys don't want to get beat by a turbo busa, do you?
So here's the deal, any of you guys with a 14 in the SF Bay Area want a supercharger unit at cost? Tuned and installed for free as well. The catch is that I have to borrow the bike for a few days to begin with while I get dimensions for bracketry and plenums, then a week later once everything is fabbed up.
Let me know guys!
Jason Keats
_________________
N/A is slow.
D
posted May 30, 2006 05:26 PM
IF.....
That shop has a good reputation then great.
Butt...
There are VERY few blower kits on the market and there's a reason for that. I'd be doin a whole lotta research with this cuz it's still gonna cost ya $5+K at "cost" and the R+D time will be extensive too.
Consider the options - Muzzy had already stated a few months ago here that the 14 turbo kit will be on it's way.
TJ
posted May 30, 2006 05:28 PM        Edited By: TJ on 30 May 2006 18:29
Do it
posted May 30, 2006 05:55 PM
Do it!
Stalwart
posted May 30, 2006 07:02 PM
Putting a supercharger on a 12:1 motor seems like a dumb idea to me unless you can purchase race gas everywhere you ride. On my turbo bike I went with LOW compression pistons and more boost but at least with a turbo you can dial boost up and down with the waste gate. On the old Kaw I could use moderate boost, 18lbs, on premium pump gas and a bit more with my water injection tank filled.
I admit my 8:1 compression pistons made for less torque off boost, but at 1392cc it still was no slug and 27 psi of boost was available (highest I ever set the wastegate) at about 5000 rpm and still significant boost down as low as 3000 rpm.
Stuart
Ridin' the Trump train.
posted May 30, 2006 08:05 PM
Stalwart good points. it's not a deal yet I have questions main one is the 12:1 issue I don't want to be putting windows in pistons and still need to run on pump gas. but it may be able to run 3 - 4lb with a ignition retard unit from Schnitz. like i said lots of qestions. and to answer D look at their sight full kits are $4500 so I am hopeing for around half of that. But I have been wrong before- many times to be exact.
thevak
posted May 30, 2006 09:14 PM
A super charger yeah that's what we need lmao just buy a f#*kin plane.........
  Ignore this member    Click here to visit thevak's homepage.
Stalwart
posted May 31, 2006 10:59 AM
3-4 lb. would probably give you in the neighborhood 35 to 40 GROSS horsepower increase but you would probably have only about 20-25 NET horsepower increase due to the power required to run the supercharger. For even half the cost at $2250.00 it isn't much of a bargain. I bet you can spend that kind of money elsewhere and make even more power without the extra weight.
I have a lot of supercharged and turbocharged engines and there is no free lunch with any of them. On my boat engines, it takes about 100 hp just to drive the supercharger.
Stuart
0.21170210838318 seconds processing time
