BIKELAND > FORUMS > ZX-14.com > Thread: Speedo correction NEW TOPIC NEW POLL POST REPLY
TJ
posted May 27, 2006 10:12 AM
Speedo correction
For those that went with a 16T countershaft sprocket and installed a yellow box/speedohealer....
What % correction did you use?
posted May 27, 2006 10:18 AM
the error factor could be different as potentially each bike could be out (stock) by a different percentage.. best way to calibrate it would be to put it on a dyno... 2nd best way would be to use a GPS... 3rd would be to pace yourself against a friend's car at a given speed, and then work the calculation based on that.
vegasdude
posted May 27, 2006 10:44 AM
any pics of install?
posted May 27, 2006 11:55 AM
where did you get the yellow box, and does it work on the zx14?
vegasdude
posted May 27, 2006 12:38 PM        Edited By: vegasdude on 27 May 2006 13:38
Get the Kawasaki plug and go kit number 1
http://www.calsportbike.com/cgi-bin/store/index.cgi?pid=800
I t's so much easier to install and more accurate than the yellow box. Get the EXT version so you can recall you fastest speed at any time.............
zx1kr
posted May 27, 2006 12:52 PM
Does anyone have a SpeedoHealer hooked up? Which is the more user friendly , SH or the Yellowbox? I have a SH on my 10R it was a piece of cake to install. It was not so easy on my 05' 636R. Want to go with the set-up that won't require cutting & splicing, plug & play would be preferred.
posted May 27, 2006 12:54 PM        Edited By: dubious on 27 May 2006 13:55
Too cool!
For sure? this will work with can bus, and all the other fandangled crap of the zx14 ?
I will order one right away!
Pipe, Pc3, tie down kit, dead mans switch, clip ons, lower link, fan, PAR block off plates, and sprocket are on the plane!
Extended swing arm, and few other details and I will be rockin!
Vegasdude have you installed this calibrater?
TJ
posted May 27, 2006 12:56 PM        Edited By: TJ on 27 May 2006 14:02
I ordered the speedohealer on Thursday. They shipped it on Friday. Should arrive on Tues. I will post pics once I get it installed.
vegasdude
posted May 27, 2006 01:00 PM
cool. I would appreciate the Pics.......Thanks..........
vegasdude
posted May 27, 2006 01:01 PM
Too cool!
I installed one on my 10. Which means any 5 year old can do it................lol
vegasdude
posted May 27, 2006 01:03 PM
The 14's are plug and pray......er I mean "play"...............
posted May 27, 2006 01:04 PM
Thanks bro!
vegasdude
posted May 27, 2006 01:05 PM        Edited By: vegasdude on 27 May 2006 14:06
This link gives you an idea on how the SH is installed on the 10.
http://www.zx-10r.net/forum/showthread.php?t=4953
SanteeZX14
posted May 31, 2006 11:45 AM
SH on the 14 is real easy - Get the KAW1 harness - The factory harness is just behind the idle adjuster.
2006 ZX14 (Faster RED Version)
2004 EX250 (Baby Ninja)
2003 ZRX (Green of course)
0.24930500984192 seconds processing time
