BIKELAND > FORUMS > ZX-14.com > Thread: Interesting observation about the low end NEW TOPIC NEW POLL POST REPLY
zx9rmal
posted May 27, 2006 09:12 AM
After riding the bike for 1,000 miles, I've noticed something about the bike's throttle response. It is, indeed, soft down low. BUT, although at 3,000 to 5,000 rpm just turning the throttle about 1/2 way doesn't do much, when you turn further, the bike suddenly pulls harder. It's as if either the timing changes, or more fuel is suddenly added.
Anybody else notice this? It is, however, more pronounced with the 16T front sprocket.
Mal Glanz
Ft. Lauderdale, FL
'12 ZX-14R
TJ
posted May 27, 2006 09:16 AM
Discussed at length...
http://www.bikeland.org/board/viewthread.php?FID=27&TID=23920&set_time=
http://www.bikeland.org/board/viewthread.php?FID=27&TID=23549&set_time=
zx9rmal
posted May 27, 2006 09:45 AM
What I'm talking about, the increased response when opening the throttle past a certain poimt, wasn't mentioned in those threads.
Mal Glanz
Ft. Lauderdale, FL
'12 ZX-14R
vegasdude
posted May 27, 2006 09:51 AM
I have to agree. When the throttle is turned more fuel is added! Ha!
D
posted May 27, 2006 10:29 AM
I always felt that was the case with the 98 9R I had and also with the 12 (not refering to the obvious more fuel added but more like different map in use for WOT).
I never did get a confirmation as to whether is was a function of the K-TRIC ignition or not.
zx9rmal
posted May 27, 2006 10:57 AM
Thanks for the confirm. And here I thought I had a one-off bike. )
Mal Glanz
Ft. Lauderdale, FL
'12 ZX-14R
aughtsix
posted May 27, 2006 12:05 PM
That sort of makes sense...
Dyno runs are conducted full throttle, of course, and I've noticed that the dyno graphs posted show pretty linear curves - no noticeable, pronounced dips or "softness".
What would be interesting is if someone could design some software that would produce a dyno curve -and- show the relationship between power production and throttle position.
0.21469688415527 seconds processing time
