BIKELAND > FORUMS > ZX-14.com > Thread: caught in the rain My 14 seemed to sneeze NEW TOPIC NEW POLL POST REPLY
northmedic
posted May 23, 2006 08:13 PM
Well after cleaning my 14 and wax the heck out of her i went for a ride and dark sinister cloud came out and started to pour out i stopped at a friends waited for the rain to pass when i left i started my 14 waited a 30 sec or so and left the dam thing seemed to sneeze 3 or 4 times then picked right up any ideas weird ???????????
dbeadling
posted May 23, 2006 08:27 PM
PLUGS REALLY EASY TO FOUL IF YOU TOUCH THE THROTTLE WHEN STARTING BIKE MAY BE THE 1400 DOES NOT LIKE THE WATER???????????
northmedic
posted May 23, 2006 08:29 PM
i let it warm up all the good things just a glitch i guess
posted May 24, 2006 04:05 AM
Caps Lock - troll sighting?
Stalwart
posted May 24, 2006 06:08 AM
C'mon FBA, SWFT has given the alert. 3 . . . 2 . . . 1 . . .
Stuart
Ridin' the Trump train.
speedgene
posted May 24, 2006 07:33 AM
I could only guess at this point? You have a few sensors...one stationed at the nose(?), one at the tail, and the other plumbed on the FI system.
The guess here is; did one or all sensors take a reading in the rain? My guess is yes; all checked in with the ECU. What "pop" or "sneeze" happened, was a map change brought on by the FI sensor? Because these sensors are silicone wafer signaled, the vacuum behind the wafer, is reading a much wetter atmosphere? I assume the pull behind the wafer needed more vacuum to disturb the wafer, which then drops a different reference point in voltage, so the ECU can switch to a different map signal. Because now... there is heavier air inside the sensor's entry tube to cause more resistance on the wafer?
As sloppy as the transition is to change over to a different spray signal (more dense air = more fuel required) my guess is that the engine threw the "sneeze" routine before switching and/or re-mapping to a richer signal?
It was a sneeze or two, and all was well... correct? If it's still doing it, then there is an air leak in the intake system somewhere?
E-tard
northmedic
posted May 24, 2006 09:09 AM
it only did about 3 as i took off in 1 gear
zx61114
posted May 24, 2006 10:05 AM
I will be all over the eastern US this weekend. I'm sure at some point I will hit some rain. I hope this is not an across the board problem, but if anyone is going to find out there is a problem it's me.
0.24552893638611 seconds processing time
