BIKELAND > FORUMS > ZX-14.com > Thread: Is the countershaft sprocket welded on? NEW TOPIC NEW POLL POST REPLY
CrazyKenny
posted May 20, 2006 06:11 AM
Is it left handed threads? If any one has had it off yet was it difficult to do. I have used two different types of impact wrenches and can't get it off! Please help!
zxbob
posted May 20, 2006 06:14 AM
Righty ..... tighty !
Lefty ....... loosey !
Mama Kaw did'nt weld em. Turn up the torque on you gun, or try another.
CrazyKenny
posted May 20, 2006 06:21 AM
Time to break out the torches!
12r1
posted May 20, 2006 06:41 AM
No no, relax dood!! LOL Don't torch on your 14..
Does it have the lock washer, as the 12 does?? Don't know your mechanical level, please don't be offended.
Get a piece of 2x4 or sumthin' through the rear wheel, on top of the swingarm, and find the longest piece of pipe you can on the end of your ratchet/ breaker/ whatever. Trans in neutral, pull on that sumbitch, it'll go.. Make sure you pad the top of the swingarm(where your block will hit), so you don't mar the arm.
I've done it this way on my 12 many times.
jeff
Y2KZX12R
CompetitionCNC.com
posted May 20, 2006 09:17 AM        Edited By: Y2KZX12R on 20 May 2006 10:18
Hey, dont use impact guns on the sprocket nut guys.
You can damage the gears and dogs.
Besides its much easier to put a 2x4 or somthing wood like a shovel handle thru the rear wheel agenst the swingarm on both sides and use a breaker bar. Its VERY easy this way.
TJ
posted May 20, 2006 09:35 AM
+1
Outsiderzx12r
Street Racer
posted May 20, 2006 11:24 AM
I tried that on my countershaft sprocket on the 12 and it did NOT work....
OutsiderZX12R
2000 ZX12R-A1
  Ignore this member    Click here to visit OutsiderZX12R's homepage.
zermatt
posted May 20, 2006 11:32 AM
Why would a few taps of an impact wrench to a bunch of damage to your gears if you're in neutral? Sure, if you sit on the impact button for a couple of minutes, it might start to do things that you don't want, but hitting it a few times isn't going to cause major problems on hardened parts inside the tranny.
On the other hand, if it doesn't break free right away with a few taps from a good, strong impact wrench, it's time to break out something with a lot more mechanical advantage... but even then you're putting a lot of stress on the aluminum casing... which is worse? Impact hits that are really only putting stress on the sprockets and chain, or applying 500+ ft lbs via a long breaker bar extension, potentially causing the case to crack or oval the output hole?
blitzkrieg
Road kill = Free lunch.
posted May 20, 2006 02:10 PM
Outsider's sprocket overwhelmed my old impact wrench and bent my breaker-bar. That fucker was ON there.
I have since upgraded to a high-dollar Snap-On impact wrench that would twist Osama Bin-Ladens location out of the most loyal Jihadist.
Put the bike in neutral (important unless you want to learn how to split engine cases), wrap the spokes with towels, put a 2x4 through the wheel just above the swingarm and hit it with the big gun.
jimzx9r
posted May 20, 2006 06:52 PM
I had a breaker bar with a 6 foot pipe on the end when I took off the factory sprocket. Myself and another friend were pushing on that bar while another friend was on the bike, the bar started to bend and then the bike was getting lifted off the ground...so we got another friend to sit bitch on the back...it still lifted up and wouldn't break loose. There was no way it was coming off without an impact.
blitzkrieg
posted May 20, 2006 07:01 PM
My experience exactly Jim.
Three 200 lbs + guys and it wouldn't budge.
I was afraid we were going to break something inside. We gave up and Outsider had his Dad hit with the impact at his shop.
zermatt
posted May 20, 2006 07:47 PM
I bought one of those "Earthquake" impact wrenches at Harbor Freight not too long ago and have been pleased as hell with it. I think it's torque rating is somewhere in the 550-650 range. Not a bad deal at all for the $69 I paid. I'm all for Snap-On stuff, but I just couldn't justify their prices for an impact wrench that I, personally, will never use enough to wear out. I'd put money on it right now that this wrench will spin that little nut off in no time!
Well... I'd be pushing it with about 150lbs of air if necessary too...
TJ
posted May 20, 2006 08:41 PM
I just change the rear sprocket.
zermatt
posted May 21, 2006 06:49 AM
I know that's much simpler, but don't you have to increase by 2-3 teeth to get similar results as going down 1 in the front? And wouldn't that increase the possibility of needing to lengthen the chain?
I haven't decided if I want to modify anything just yet, but I might be interested in increasing the rear by 1 or 2 if that didn't make the chain too short.
swiftkart
posted May 21, 2006 09:07 PM
2' breaker bar while sitting on the bike with my foot on the rear break (lock washer undone) and it came off with just a little muscle, 16t installed, speed corrector installed, bike runs even better and the fuel milage increased about 3 mile to the gal.
flite leader
posted May 22, 2006 03:35 PM
while a hammer gun will get the nut loose
or remove it
the threads will be knackered
will give you a false torque reading when replaced
which will cause inadequate...... stretched .... & broken parts
hammer guns are for convenience
i know of no good mechanic that will use one on a bolt
or stud or nut that torque is critical
the whirring ratchet does no harm unless you cross thread something
always better to use a breaker bar
at 90 degree angle
good luck
bend your mind.....
or break your ass...!!
zx9rmal
posted May 22, 2006 03:53 PM
Is there enough chain to go +3 in the rear?
Mal Glanz
Ft. Lauderdale, FL
'12 ZX-14R
CrazyKenny
posted May 22, 2006 04:36 PM
YES, WE HAVE IGNITION!!! Just got the sprocket off. It took 170 lbs of air and a IR Thunder Gun 650lbs of NBT!!!!! God damn rediculous!!!!!!!
zx9rmal
posted May 24, 2006 07:18 AM
Anyone know the torque spec for the front sprocket?
Mal Glanz
Ft. Lauderdale, FL
'12 ZX-14R
Megabyte
posted May 24, 2006 07:25 AM
Same here...
zerMATT
posted May 24, 2006 07:30 AM
That's a bad-ass gun!
mustmoto
e-famous
posted May 24, 2006 09:19 AM
92 foot pounds
Some people will tell you that slow is good - and it may be, on some days - but I am here to tell you that fast is better. I've always believed this, in spite of the trouble it's caused me. Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba.... ---HST
  Ignore this member    Click here to send mustmoto an AIM message.
zx9rmal
posted May 24, 2006 09:56 AM
92 foot pounds
Thanks.
Mal Glanz
Ft. Lauderdale, FL
'12 ZX-14R
0.33592414855957 seconds processing time
