BIKELAND > FORUMS > ZX-14.com > Thread: Reed valve block off plates? NEW TOPIC NEW POLL POST REPLY
Stalwart
posted May 09, 2006 09:04 AM
Do you guys recommend the reed valve block off plates when installing a new after-market exhaust?
Stuart
Ridin' the Trump train.
posted May 09, 2006 09:30 AM
I thought this bike was a close loop fi system. if so, that would have a big effect on fueling. if not, go for it!
Stalwart
posted May 09, 2006 09:43 AM
VERY good point, I haven't looked for an O2 sensor. I haven't done any mods to a closed loop system without a reprogram, I consider a reprogram essential and I await the arrival of maps from Muzzy. I'm still awaiting the Muzzy Ti/Ti oval. When I install the new pipe would be the time for the block off plates but you're right, not without a reprogram if it's a closed system.
Stuart
posted May 09, 2006 09:47 AM
yes its closed loop!
posted May 09, 2006 10:08 AM
I'll wait for the experts to chime in, but was thinking the block off plates would make the map go way way lean, since you wouldn't get all the oxygen it was expecting.
TJ
posted May 09, 2006 10:13 AM
Wouldn't less air make the map rich?
posted May 09, 2006 12:48 PM
Gah!...Think yer right!
zxbob
posted May 09, 2006 04:33 PM
I installed the Muzzy Block offs.
No difference in performance ........... Allowed the removal of the Ca. emissions
Shaved some weight, did not affect the running at all.
posted May 09, 2006 06:45 PM
That's interesting...Wonder if the bike is really closed loop?
zxbob
posted May 09, 2006 08:06 PM
There is no 02 sensor to tell the ECU whats in the exhaust - block offs wont
affect anything ................ except an emissions test.
FasterThanStink
posted May 09, 2006 08:15 PM
No O2 sensor means no closed loop FI.
That's what gets you.
0.21563196182251 seconds processing time
