BIKELAND > FORUMS > ZX-14.com > Thread: COUNTERSHAFT SPROCKET NEW TOPIC NEW POLL POST REPLY
bbirdxx2000
posted May 06, 2006 04:37 PM
I am planning on putting a 16 tooth up front. This bike is geared to tall and I am never gonna bury the speedo. My question is, will the sprocket effect the computer, and will it also throw my speedo off.
9.96 @ 143 stock with flies removed
posted May 06, 2006 04:44 PM
Yes it will affect the speedo and odometer.
TJ
posted May 06, 2006 04:59 PM        Edited By: TJ on 6 May 2006 18:00
Get a yellow box to fix the speedo/odometer error
bbirdxx2000
posted May 07, 2006 03:15 AM
Thanks!!!!!!!!!!!!!
bbirdxx2000
posted May 07, 2006 03:21 AM
Next question: how many teeth can I go up in the rear with the stock chain, 2 or 3 ?????
posted May 07, 2006 08:52 AM
you can go as large as you like.
To hit the rev limiter at 300 km/h or 186 you could go from 17/ 41 stock to 16/43.
Stock gearing equates to 202 mph if it could pull it .....at redline.
16/43 = 186 mph at redline .
For local rides and drags this may be the way to go, but fuel mileage would suck.
With such a low 1st gear an additional gear change would probably be necessitated in the 1/4 so some losses may be seen from the gain .
bbirdxx2000
posted May 07, 2006 12:13 PM
Good points, going up 2 in the rear should only drop about 300 RPM at 80 MPH. I would rather have the extra power down low. I will never go close 186
posted May 08, 2006 05:10 PM
Is the front sproket the same part as a zx12r?
fastestbusaaround
I eat Fish...
posted May 08, 2006 06:19 PM
Fuel mileage already sucks...
FYYFF!!!
posted May 08, 2006 06:24 PM
bahhh fuck it ,
Cruising around town I get 40 MPG, on highway 32-34 mpg at 160!
Want to stretch and have a smoke after 2 hrs anyway.
Mind you if we could get the bottom end derestricted, and a pipe....
flite leader
posted May 11, 2006 03:09 PM
simply better to do when you need a tire & chain replacement
no less
that you are mature enuf to know & admit
you are Not "Ricky Racer"
the advantages are in your favor
if you use your mid range judiciously
are not prone to winding out each gear
in essence "short Shifting"
as moany have discovered & use extensively
when they have vehicles that possess a lot of "Headroom" (plenty or excessive power)
you may actually experience better gas mileage
there have been plenty of bikes geared toooooooooo loooong
with 100mph 1st gears
of course no one rideds around 25.... 45.... 55mph zones
in 1st gear
ther is a lot of merit & several advantages for what you intend to do
good luck
bend your mind.....
or break your ass...!!
0.32628607749939 seconds processing time
