BIKELAND > FORUMS > ZX10R ZONE.com > Thread: 06 zx10 occassional skip NEW TOPIC NEW POLL POST REPLY
nhzx10
posted June 16, 2008 05:56 PM
my bike has started hiccuping every once in a while, it feels like the ignition cuts out for a fraction of a second then comes right back. No engine light has come on and it doesnt happen at any particular rpm, although it does happen more often when im right into it. I talked to a tech and he told me that the power commanders have been eating the ecu's??and this could be the problem but no real way to tell...Has anyone else experienced this and possibly lead me to a fix?
kz2zx
Nobody in Particular
posted June 16, 2008 08:07 PM
One, check the sidestand position switch. Mine would cut at 10,000 RPM or so, worse when cold.
Two, check the battery connections and be sure the PC is grounded to the negative battery terminal, not the frame.
Three, the handlebar kill switch.
Four, the PC block.
ASMA 47
WERA 147
www.dhowellbooks.com
nhzx10
posted June 17, 2008 05:39 PM
Thanks! I started ripping into it this evening and took apart the kickstand switch-full of water!! What a shitty design....I dont even use a pressure washer and dont really ride in the rain or park it outside, this is the first bike ive ever had thats had this problem....here comes the silicone!!!!
ninja_12r2000
posted June 28, 2008 05:11 PM
Silicone run the world even for girls. Imagine, what that can do for your bike.
Good luck.
0.36294889450073 seconds processing time
