BIKELAND > FORUMS > ZX10R ZONE.com > Thread: removing CATS from exhaust NEW TOPIC NEW POLL POST REPLY
Don10r
posted September 01, 2006 11:33 AM
Hey everyone,, was just reading some earlier stuff and saw a post about removing the CAT from the exhaust system ....what are the benifits ...if any ...and how hard is it to do ? I'm also lookin at exhaust systems...want something that will give my 04 10r a deep growl...any suggestion ??
OOOO! Thats gonna hurt right away!
D
posted September 01, 2006 12:27 PM
SEARCH!!!
It's not just for breakfast any more.
2nd10r
posted September 03, 2006 07:24 PM
As for an exhaust system, check out www.areapnolimits.com. I have the Extreme Series High Mount Half System Slip-On. It mounts at the head pipe collector flange and removes the catalytic converters, as well as the exhaust valve. It features a racing style merge collector tig welded to a stainless steel flange similar to the OEM flange. The Extreme series muffler is 14" long with a 2.25" diameter core & outlet tip. The muffler body clamp mount is laser cut from 304 series stainless steel with an extruded rubber insulator. I got the muffler in Carbon Fiber. Lightweight 304 series Stainless Steel is also available. The Extreme 14" muffler, 2.25" core & 2.25" outlet tip at idle is 90 - 91 dbA and at 5000rpm's is 100 - 101 dbA. Power increase was approx. 5 horsepower and 2 foot pounds of torque. Fuel curve is within specs and no change is required to the mapping. Exhaust is pretty simple to install.
The pipe is on an 06' 10R and sounds great. Very throaty sound, looks beautiful and definate performance increase. I am highly reccomending Area P. Contact Kerry @ Area P. He has been building pipes for many years and is very helpful.
0.26386094093323 seconds processing time
