BIKELAND > FORUMS > ZX10R ZONE.com > Thread: head gasket and cams? NEW TOPIC NEW POLL POST REPLY
ikezixxer
posted September 29, 2005 06:31 PM
Well I read about getting alot of HP out of head gasket and cams...what are these, how much do they cost, and what sort of power increases am I looking at? total cost of instalaltion and parts, ect?
Hells Dark Lord
living life, and loving it.
posted September 29, 2005 07:17 PM
if you are going to make the intake breath better, to get the most of it, you will need to make the exhaust breath better....tha tmeans full exhausts and degree wheels....filters, and such......if you use the head gasket you will prolly have to run 93 or better gas....as opposed to the 90 octane recommended.....
Cams are alot of money, for not that many ponies.....they woudl be one of the last things I did, after some cleaning of the posrts, maybe back cut the valves and everythign else I coudl do to the head, if I were going with cams.....just some thoughts
TedG
posted September 29, 2005 07:50 PM
I am going with a thin head gasket and a slip on . The good part is I can still run 90 octane because I have already lost almost 2 compression points by living at 4500 feet.
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
o
posted October 28, 2005 08:30 PM
I just had the performance cams ordered. Anyone have a map for the following: bmc race filter, akra slip-on, pc III (usb), race gasket and valve adjustment(if that matters)?
PBO ZX10R
justoyz2
Justoyz Racing
posted November 04, 2005 04:37 AM
the head gasket cost 17.00 and the cam is around 200 or so. I think the cam should give you some good power. The duration on the stock cam is 300 with a lift of 358 (03583).
The duration on the Kawi cam is 310 with a lift of 382(03819)
As you can tell this cam is alot larger then stock. I am sure the cam will give more mid to top end power increase. In order to see the increase, most case you will need to raise the compression (thinner head gasket or milling the head or cylnder)
Thinner head gasket: stock is .65 mm =0256
Kawi AM .40mm = 0157
That's roughly 10 thousandths off your head or cylnder
DB
posted November 04, 2005 05:10 AM
You need a custom map done if you want to most from your bike. Trust me, don't skimp with others maps and get one done. You'll be glad you did.
Dan
04 ZX10r (Track only)
08 Concours14
steamr
2006 black ZX-10R
posted November 04, 2005 08:26 AM
Hey everyone, I'm new to this forum. I agree have your bike customed mapped. I gained 9 hp on a custom map compared to a matching exhaust map. 2004 zx10
0.23559308052063 seconds processing time
