BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Torq Specs NEW TOPIC NEW POLL POST REPLY
HON825
posted September 27, 2005 01:14 PM        Edited By: HON825 on 27 Sep 2005 14:15
Torq Specs
Does anyone know what is the torq spec for the following. Rear main axle nut, front brake caliper mounting bolt, rear brake caliper bolt, the front pinch bolts on the forks and the front main axle nut. Thanks!
Luke
  Ignore this member    Click here to send HON825 an AIM message.
beansbaxter
posted September 27, 2005 01:35 PM
Rear main axle nut, 81
front brake caliper mounting bolt, 25
rear brake caliper bolt, 18
the front pinch bolts on the forks - upper is 14.5 and lower is 22
and the front main axle nut. 81
all settings are ft/lb
hon825
posted September 27, 2005 01:39 PM
Thanks beansbaxter.
Luke
HON825
posted September 30, 2005 08:23 AM
beansbaxter,
Do you know what is size of that big center nut on the triple clamp? Also what is the torq for that particular nut. Thanks!
timsterc
posted September 30, 2005 09:03 AM        Edited By: timsterc on 30 Sep 2005 10:04
Chap,
The online parts guide at www.buykawasaki.com says it's a 28mm.
58 ft/lb for "Stem head nut".
Shiney side up,
Sticky side down.
;o)
  Ignore this member    Click here to send TimsterC an ICQ message. Click here to add 89556129 to your ICQ list. Click here to visit TimsterC's homepage. Click here to send TimsterC an AIM message.
timsterc
posted September 30, 2005 09:44 AM
The online parts diagrams can be found here. Don't forget to select the correct year for your bike.
http://www.buykawasaki.com/Site/PCProductCatalog/PCCatItems.asp?intCatalogID=1&CatalogTypeID=4&ProductTypeID=14&ModelMarketingId=565
Shiney side up,
Sticky side down.
;o)
beansbaxter
posted September 30, 2005 01:05 PM
WRONG!!
I just did this like an hour ago, my service manul is still on that page, the big center nut on the triple tree, according to page 14-8 in the service manual, is 14.5 ft/lb for the "steering stem nut"
CanyonCarver
posted October 01, 2005 05:34 AM        Edited By: CanyonCarver on 1 Oct 2005 06:35
Look again. It's 58. 14.5 is for the steering nut under the triple-clamp. Not the one above. And you may want to re-torque yours if it's at 58. Not a good one to randomly work loose.
beansbaxter
posted October 01, 2005 07:47 AM
aaaah you are right, i was talking about the one above.
0.23972606658936 seconds processing time
