BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Suspension setup NEW TOPIC NEW POLL POST REPLY
hodge47
posted September 17, 2005 09:36 AM
Suspension setup
Just taken delivery of a black Zx10r and yup the rear shock is hard as hell,
can anyone advise on adjustment for a 200lb rider for fast toad riding, bearing in mind i,m a suspension numpty.
Has anyone resprung the rear shock with progressive, and if so did it help
Cheers guys
Ground Zero
posted September 21, 2005 12:23 PM
You need to first adjust the sag and go from there. Front should be around 35mm and the rear between 25-30mm (rider sag). THen you can dial in the comp/rebound to your liking. Hope this helps.
posted September 21, 2005 12:37 PM
there is an excellent topic about that in this forum with settings already... here.. just do as this topic says.... http://www.bikeland.org/board/viewthread.php?FID=19&TID=16927
0.23061394691467 seconds processing time
